Bed rear tack welds
Everyone that's disassembled a fleet side bed have you tack welded the rear upright to the cross member again? Factory assembly manual shows 3 small welds. Is it really necessary?
#2 | |
The Older Generation
Re: Bed rear tack welds
Yes. It's pretty important to do that. It keeps the bed from racking. Just make sure you have the tailgate fitting good before you weld it. LockDoc
![]() Join Date: Mar 2023
You have a photo of where them welds go. I’m curious
I’m doing mine now |
#5 | |
Lower left |
Like Doc stated make sure your tailgate is a proper fit before welding.
I put an arrow on Howzzit's picture. There is usually one spot of weld close to each corner. LockDoc
As in 9-A and 9-B.
'67 GMC 2500, 292, 4spd, AC |
![]() ![]() Join Date: Apr 2022
I did a little more weld on the underside of my box as I painted it prior to assembly and I didn't want to mess the paint for that little tack on the floor to the pocket. Its holding up so far from the all the rough roads around here.
The Twins: 1968 C10 SWB - Blue 327/5 Speed 1968 Camaro SS/RS - Blue 327/4speed C10 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=833278 The "Others" 1933 Ford Pickup (Camaro in disguise) 2017 Camaro SS Life long Chevy guy |
Appreciate all the information
| Bookmarks |
