Old 12-27-2023, 07:32 PM   #1
vardenafil
Truck stumbles when cold
I recently changed my oil when the problem started IÂ’m donÂ’t know if itÂ’s related or not. We are having a cold streak here itÂ’s in the 60s. When I drive the truck it feels like it stumbles. It never actually stalls it just feels like itÂ’s going to and the power drops out. The truck seems to start normal it does seem to idle weird at stoplights. Is this something to do with the cold or my oil change?
vardenafil is offline   Reply With Quote
Old 12-27-2023, 07:58 PM   #2
RustyPile
RustyPile's Avatar
Re: Truck stumbles when cold
I don't see how a simple oil change can cause engine stumble, so I'm going with ambient temperature.. Check choke operation and fast idle setting. Also TCAC operation is critical in cold weather.. Posting the checking and testing procedures are a lengthy writeup. Refer to the Factory Service manual for these items..
RustyPile is offline   Reply With Quote
Old 12-27-2023, 08:04 PM   #3
howzzzit
howzzzit's Avatar
60 isn't cold. Check your idle mixture.
howzzzit is offline   Reply With Quote
Old 12-27-2023, 08:09 PM   #4
dmjlambert
dmjlambert's Avatar
I was having my truck stumble and often stall upon startup when it's colder, and I adjusted the choke to have a slightly more open choke plate when cold, and that resolved it for me.
dmjlambert is offline   Reply With Quote
Old 12-28-2023, 11:37 AM   #5
1967GMCC20
1967GMCC20's Avatar
Vacuum leak, hose line, might have got bumped when you were adding oil, air cleaner moved, ect. Spray carb cleaner around intake, careful, focused area.
What vehicle do you have. Eng, trans.
1967GMCC20 is offline   Reply With Quote
Old 12-28-2023, 12:27 PM   #6
PanhandleShantyman
Is it stumbling all the time, intermittently, or just on acceleration?
Timing issue? Mine stumbles on acceleration if I don't have the timing advanced a little bit from spec. I haven't chased down the reason why yet (it's gotta be either the vacuum or mechanical advance is lazy, I guess), but it runs ok if I put the timing at +13 or so.
A $15 vacuum gauge/fuel pump tester combo from Harbor Freight would let identify or rule out vacuum leak and bad fuel pump. Plus there are wise men on this forum who can tell you all about reading the tea leaves of vacuum gauge behavior to diagnose other issues.
PanhandleShantyman is offline   Reply With Quote
Old 12-28-2023, 03:13 PM   #7
vardenafil
Thanks I’ll take a look at the idle and choke this weekend.
Old 12-28-2023, 07:54 PM   #8
Steeveedee
Ram-A-Lam-A-Ding-Dong
Steeveedee's Avatar
Here is a vacuum chart to use.
~Steven
Simi Valley, CA
Old 12-29-2023, 02:05 AM   #9
slikside
slikside's Avatar
Nice vacuum legend there. Thanks for posting.
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, HEI, mostly stock, Survivor.
slikside is offline   Reply With Quote
Old 12-29-2023, 11:53 AM   #10
Steeveedee
Steeveedee's Avatar
Thanks! The header in the pic shows I got it here, so thanks to whomever posted it before, too.
~Steven
Simi Valley, CA
Old 12-31-2023, 10:05 PM   #11
vardenafil
Do I use that chart with the engine at idle or when I give it throtle? Or both?
