Old 12-30-2023, 11:59 PM   #1
3drburb
1989 Cheyenne 1500 Wiper Relay?
After about 20 years of owning this truck and using it mainly for dump runs or to haul stuff in the Spring and Summer, I was driving it this week in the rain only to notice that my wipers do not have a low speed.
Is this normal?
Is there a common fix, and or what are you all using for an aftermarket intermittent wiper relay, if that will fix it?
I am thinking if it's not fixed soon, I will forget about it for a couple years.
Thanks in advance.
3drburb is offline   Reply With Quote
Old 12-31-2023, 10:50 AM   #2
3drburb
Re: 1989 Cheyenne 1500 Wiper Relay?
I checked out You-Tube only to learned that this and other wiper issues is common problem for these years, so hopefully it should be fixed with a newer style replacement motor.
Thanks.
On a side note, I forgot how much space and leg room these cabins have compared to the earlier years.
Old 12-31-2023, 11:15 AM   #3
Swap out the wiper control module with a new one. That is the part between switch and motor that controls wiper functions
Old 12-31-2023, 06:36 PM   #4
3drburb
Thanks for information. Just called the local parts store after reading this and they will have one in for me soon.
Old 01-01-2024, 08:40 AM   #5
I hope that helps.
Old 01-02-2024, 03:16 PM   #6
95 S_Trucker
95 S_Trucker's Avatar
The 88-90 wiper pulse board is not produced anymore. You cannot install the newer pulse board onto the old wiper motor. If you don't have the newer wiper motor already, I would get one. It will come with a new pulse board on it.
95 S_Trucker is offline   Reply With Quote
Old 01-02-2024, 07:45 PM   #7
3drburb
So, I should be good with the purchase of a 92 wiper motor?
Thanks.
Old 01-03-2024, 09:13 AM   #8
Great helpful information here. I'm surprised no one makes these, though. There's no shortage of these trucks in use daily, let alone them becoming popular classics. My '99 Sonoma needs one. There are four choices from four companies on Rock Auto offering
Old 01-03-2024, 09:28 AM   #9
95 S_Trucker
The pulse boards for the new design wiper motor that started in 91 are plentiful. Not 88-90.
Old 01-12-2024, 06:37 AM   #10
I did get that. I'm saying it's strange no replacement part companies make these. Plenty of 88-90s out there yet.
Old 01-12-2024, 11:46 PM   #11
Bob B.
It's true, the circuit board is only available for '91 and newer. You can replace the motor assembly for '88-'90, you can usually find rebuilt for less than $100.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90.
Bob B. is offline   Reply With Quote
