01-06-2024, 12:34 PM | #1 |
Bad-Fitting Cab Corner Speaker Enclosures
Does anybody have a recommendation to a set of better fitting speaker enclosures? Here's what I am dealing with at the moment:
They fit well on the sides but they're a few inches too short and don't match the angles of the cab and floor. I could bend the bottom angle section a bit more for a better fit there but that would lower it to the point of having probably a 2" gap at the top. Are the ones out there all the same? I got the cheapest set on eBay so maybe that's a clue...
1966 C10 Custom Cab Restomod (Sold) 1969 Camaro Z/28 (Keeper) Current Build: 1968 C10 (Semi-Factory Restoration) 1983 Camaro Z/28 (Next in line, Keeper) 1951 3100 (2nd in line) |
01-06-2024, 01:02 PM | #2 |
Re: Bad-Fitting Cab Corner Speaker Enclosures
A member here makes them.
His last response to the thread was on 04-27-2022 . He does have a website mentioned at Post #722. I will post both links below. Link to sale thread: https://67-72chevytrucks.com/vboard/...d.php?t=476976 Link that is in post# 722 of 1st link: https://73-87.com/Parts/6772SpeakerB...20Brackets.htm Hope this helps.
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
01-06-2024, 01:41 PM | #3 | |
Junior Member
01-06-2024, 01:45 PM | #4 | |
The website is still active.
01-06-2024, 02:01 PM | #5 |
Junior Member
looks like he has cornered the market on corner mount speaker brackets
01-06-2024, 02:08 PM | #6 | |
01-06-2024, 05:58 PM | #7 |
You could easily add foam board to the back to fill the gaps. Then cover the entire piece with speaker cover material and the results would look professional.
71 C-20 07 Magnum RT AWD |
01-06-2024, 06:16 PM | #8 |
70+ ( Old Skool Club )
I bought a set from Big Block73 years ago and installed them last year. They fit like a glove.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
01-06-2024, 07:40 PM | #9 |
That was very first thought, "how can I modify this to work"? But, I am drawing the line this time. I'm tired of "making things work." I do it with more than 50% of the repro parts out there.
01-06-2024, 10:33 PM | #10 |
How do they look with the seat installed? How much do you even see?
