Old 01-08-2024, 06:26 PM   #1
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
How does a pre-1972 SPID designate GMC or Chevy? SPID example for GMC?
This GMC decoder for a 70-71 GMC shows just five digits for a serial number.
The 67-72 decoder shows six digits. Is that the only indicator on a SPID that distinguishes a GMC from a Chevy in 1970-71? Edit, nope: The VINS differ in a number of ways.
Thus real life example KE141Z654372 must be a Chevy? It's a SWB (model KE10734), I don't suppose many Chevy SWB K10 were built. FWW, the truck's build date is on the same day as my SWB C10, separated by <200 trucks, both serial and sequence numbers.
K = 4WD
E = V8
1 = 1/2 ton
4 = Pickup
1 = 1971
Z = Fremont
6 serial numbers
Tony 1971 C10 Custom Deluxe SWB 402/400TH A/C
I developed an assembly information kit for restoring my truck from nuts and bolts. It's written in Assy. order, short & simple, packed with all OEM hardware ID; castings; part ID; 100s of part numbers; wiring simple - Resource, and trivial too.
Much info. applies to all 67-72 GM, A/C vehicles, esp. trucks W/O saying. Full search ability, including to 700+ images of illus., parts, charts, Assy., points of interest, cab, bed, & front clip cart plans- Specials and cores were serviced out and R excluded e.g. front/rear glass, body/paint, engine core, rebuilt hinges, steering box, trans, etc.
The project was in-line with long former professions developing process, policy, specs, demo, written for novices, admin., policy, engineers, development, systems & test - Public & govt 2, gross. Sell soft copy cheaply, PM if interested.
Build thread:https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 01-08-2024, 07:16 PM   #2
71CHEVYSHORTBED402
Re: How does a pre-1972 SPID designate GMC or Chevy? SPID example for GMC?
After studying the decoders a bit more, the difference GMC and Chevy is more than just 5 VS 6 serial numbers. For starts, a 1971 GMC has a 13 character VIN while a Chevy has 12 characters.
Real Life Examples:
CE141Z654XXX
C 2WD
E V8
1 1/2 TON
4 PICK-UP
1 1971
Z FREEMONT
6 DIGITS SERIAL #
KE141Z654XXX
K 4WD
E V8
1 1/2 TON
4 PICK-UP
1 1971
Z FREEMONT
6 DIGITS SERIAL #
If the K truck was a 1971 GMC and all else equal, then the VIN would read:
KE104?Z1XXXXX
K 4WD
E V8
1 1/2 TON
04 FENDER SIDE
SPACE FOR DESIGNATION LIKE WHAT?
Z FREEMONT
1 1971
5 DIGITS SERIAL NUMBER
Old 01-08-2024, 07:25 PM   #3
Keith Seymore
Keith Seymore's Avatar
I agree; it doesn't seem to be captured in the VIN until '72.
For a squarebody it's in the model code, ie:
TK10903 = GMC, 4wd, 1/2 ton, lwb, reg cab pickup
CC20943 = Chevrolet, 2wd, 3/4 ton, lwb, crew cab pickup.
That does not seem to be the case for 67-71.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Keith Seymore is online now   Reply With Quote
Old 01-08-2024, 07:36 PM   #4
71CHEVYSHORTBED402
K
I think I figured it out Keith, post two. The "designations" in the VINs vs are about half different. They made things more difficult than they had to be, pre-1972. Perhaps whomever came up with the idea had previously worked for the government, or they had a future in it
FWW, here's a 1972 GMC decoder to add, next to a 1972 Chevy. Both follow the same logic.
Old 01-08-2024, 11:16 PM   #5
402Bowtie
402Bowtie's Avatar
67 gmc = "C" in the vin
68 gmc = "B"
69 gmc = "A"
70 gmc = "Z"
In 71, it went factory code followed by "1"...S1, Z1, etc
In 72, it went "2," plant code digit, "5"... 2S5, 2Z5 etc. Only gmc trucks had a "5" after plant code in 72.
402Bowtie is offline   Reply With Quote
Old 01-09-2024, 09:47 AM   #6
Keith Seymore
68 gmc = "B"
69 gmc = "A"
70 gmc = "Z"
Forgive me, but I am not seeing that in the VIN decoders.
https://67-72chevytrucks.com/vboard/...d.php?t=570059
[EDIT - I see it now! Chevy and GMC denoted the model years in a different fashion!]
[EDIT - That makes the following kind of moot, but I'll leave it in so my work is not wasted]
For conversation sake - I normally think of it as the plant code, followed by the sequential portion of the VIN (just the way my mind breaks it up).
I agree with your assessment for '72. It would be model year ("2"), followed by plant code, followed by sequential portion of the VIN (the serial number), where:
Chevrolet starts with 100001
GMC starts with 500001
Taking what you have pointed out and saying it differently, my summary would be:
67 GMC: (plant/year/serial) XC 1001
67 Chevy: (year/plant/serial) 7X 100001
68 GMC: (plant/year/serial) XB 10001
68 Chevy: (year/plant/serial) 8X 100001
69 GMC: (plant/year/serial) XA 10001
69 Chevy: (year/plant/serial) 9X 100001
70 GMC: (plant/year/serial) XZ 50001
70 Chevy: (year/plant/serial) 0X 100001
71 GMC: (plant/year/serial) X1 10001
71 Chevy: (year/plant/serial) 1X 100001
72 GMC: (year/plant/serial) 2X 500001
72 Chevy: (year/plant/serial) 2X 100001
That - is ridiculously nuanced.
K
1979-1986
1986 - 2019
Old 01-09-2024, 10:22 AM   #7
Keith Seymore
So - to answer the original question (that is, "How does a pre-1972 SPID designate GMC or Chevy?") the answer is it does, but it's clunky.
The '72 VIN format would be the first usage of the "modern" format, carried over into the squarebody era and (basically) still in use today.
Additionally, the actual options appear on the SPID for a square, specifically:
X88 = Chevrolet Nameplate Conversion
Z88 = GMC Nameplate Conversion
K
1979-1986
1986 - 2019
Old 01-09-2024, 10:53 AM   #8
402Bowtie
402Bowtie's Avatar
K
Almost. What you have for 69 chevy and 71 chevy aren't quite correct.
69 chevy: 9X8
71 chevy: 1X6 or 1F8
The patterns are easier to see in the build date project thread (posts 63-65).
Old 01-09-2024, 11:03 AM   #9
Keith Seymore
69 chevy: 9X8
I see it now.
So the generic decoder is not correct for 1969 Chevy (VINs start with 800001) or 1971 Chevy (VINs start with 600001 or 800001).
Thank you -
K
Udated:
69 Chevy: (year/plant/serial) 9X 800001
71 Chevy: (year/plant/serial) 1X 600001 or 1F 800001
1979-1986
1986 - 2019
Old 01-09-2024, 11:43 AM   #10
dagnabbitt
dagnabbitt's Avatar
You guys seem to be discussing 70-71, but it just to be annoying: between 67-69 Canadian GMCs and American GMCs didn't have the same VIN convention.
The Oshawa plant put a "9" in the second field/space to denote GMC. My 67 "920" is K9247... etc.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 01-09-2024, 12:17 PM   #11
Keith Seymore
Dagnabbit Dagnabbitt!
I gotta stop now before my head assplodes.
K
1979-1986
1986 - 2019
