Old 01-10-2024, 12:33 PM   #1
Rocketir
Brake Line difference between Manual and Power
I was looking to replace the hard lines and there is a different part number for Powered Brakes vs. Manual brakes. Is the only difference the location of where the lines meet the Master Cylinder? Or is there a size difference between the two? Reason I ask is I'm leaning towards manual brakes, just for the looks. But may transition to Hydro Boost if I am not happy with the feel. Currently I have stripped the truck and there is no lines/booster.
https://www.inlinetube.com/collectio...20Steel|Front|
Rocketir is offline   Reply With Quote
Old 01-10-2024, 05:22 PM   #2
72SB
Re: Brake Line difference between Manual and Power
FWIW when I converted from manual to power brakes on my 72, the manual lines all threaded into the new PS distro block.
My sense is there is some slight bend difference between the two but either could be easily massaged to work manual or power.
72SB is offline   Reply With Quote
Old 01-10-2024, 07:38 PM   #3
Rocketir
I was thinking its probably only the actual routing that is the difference. Thank you for sharing your experience. I will probably go with the Manual P/N.
Old 01-10-2024, 09:40 PM   #4
dmjlambert
dmjlambert's Avatar
I converted from manual all-drum brakes to manual front disc brakes and rear drum from a 1971 donor. I am sure glad I did that, manual brakes on my CST/10 has a great brake feel and does not require much pedal effort. It took research from members 54blackhornet, Keith Seymore, and several others to figure out the master cylinder specs and part availability. https://67-72chevytrucks.com/vboard/...39#post9169739
As far as i know, nobody has concluded on factory brakes how far from the pivot of the brake pedal lever is the attachment for the push rod and if it is really different for power vs. manual.
dmjlambert is offline   Reply With Quote
Old 01-11-2024, 04:58 PM   #5
70STOVEBOLT
70STOVEBOLT's Avatar
When I converted all drum system from manual to power, all I did was add the booster. Didn’t even unhook the lines, just carefully moved the master cylinder forward and bolted it to the booster.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 01-12-2024, 03:26 PM   #6
72SB
while using the smaller bore manual brake MC will "work"....All power brake setups used 1 1/8" bore MC. The smaller manual bore would require more braking effort and longer pedal travel....but will otherwise "work" if that is good enough for anyone's liking.
Old 01-12-2024, 03:32 PM   #7
dmjlambert
dmjlambert's Avatar
Power and manual disc brakes are both 1 1/8 bore. The amount of pedal effort and travel is trivial to me on 1/2 ton truck with manual brakes, so much so that I wonder why people are so interested in power brakes.
Old 01-12-2024, 04:25 PM   #8
72SB
drum brakes are 1" bore MC. Front Disc brakes are 1 1/8 MC.
front drum
https://www.rockauto.com/en/moreinfo...JEJD5RsPMwLpyp
\Front disc
Old 01-12-2024, 04:42 PM   #9
dmjlambert
dmjlambert's Avatar
Thanks, I edited my post above; I should have said 1 1/8 bore is for both power and manual disc brakes (71-72).
Old 01-12-2024, 05:24 PM   #10
70STOVEBOLT
I didn’t notice a difference in pedal travel, but the braking effort (leg force) was decreased due to the vacuum assist provided by the booster.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
