Old 01-16-2024, 01:09 PM   #1
rbruno68
Storing Front Clip
I just finished removing the front clip from my truck. I took it off intact. I have it stored in my garage in an upright position and sitting on the back of the fenders that normally face the door. It is heavier then I thought it would be. I am little worried that the weight sitting on the edge of the fenders might distort the fenders. I have set a goal for my build to take about a year to get the truck reassembled. Is that too long to leave the clip intact sitting upright with out effecting the fenders? Or, am I worried too much.
Thanks,
Rob
rbruno68 is offline   Reply With Quote
Old 01-17-2024, 06:40 AM   #2
joesscamaro
Re: Storing Front Clip
Are your inner fenders still attached also? If so, that would add some rigidity to all of it. As long as you can't see any tension/twisting on the fenders from too much pressure, it will probably be alright. Just my opinion.
joesscamaro is offline   Reply With Quote
Old 01-17-2024, 11:25 AM   #3
rbruno68
Yes, the inner fenders are still attached. I tied it to some sturdy shelving next to hopefully prevent it from moving or anything like that.
Old 01-17-2024, 11:12 PM   #4
cwcarpenter98
cwcarpenter98's Avatar
I took the entire front clip off and completely apart when I replaced the radiator core support several years ago. My thoughts are that it's simple to disassemble and reassemble, so if you're worried about the fenders having issues, especially if there's some rust in the structure, you'll be better off taking it all apart. It will also give you the opportunity to address any rust issues if you desire to do that.
I only replaced the core support with an aftermarket piece, so I had no trouble at all getting everything lined back up properly. I just took my time and left all the bolts loose until I got everything lined up well.
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 01-18-2024, 10:08 AM   #5
rbruno68
That is a good point. There are a couple reasons I haven't taken it apart.... yet. First is storage. I am tight for space, so it is easier right now to store it in one piece. Second, my goal for the build is to get it back together and enjoy driving while I continue to work on it and fix things. So, my vision is to put it back on in one piece. Like most of our trucks, it does need rust repair at the bottom of each fender. I did find a bit of rust on the passenger side where it bolts to the bushing. It is not completely rotted so it could go back on as is. I think a lot of what I do with it will depend on time. Yes, it would probably better to fix things while it is apart now, but sometimes I am not very patient.
Old 01-19-2024, 10:10 PM   #6
cwcarpenter98
I totally get your thought process here. It's why I haven't taken mine apart fully for the rust repair. I've been enjoying driving it too much
Christian Carpenter
Old 01-25-2024, 03:37 PM   #7
raidmagic
raidmagic's Avatar
I left mine like that for a good year with no issues. Fit right back on when I was done.
1965 C-10 1/2 ton shortbed part time daily driver
1980 C-10 1/2 ton shortbed project
raidmagic is offline   Reply With Quote
Old 01-26-2024, 09:44 AM   #8
rbruno68
That is good to know. I am hoping mine is back on the road within a year. At least, that is my goal.
Old 01-31-2024, 12:29 PM   #9
SCOTI
SCOTI's Avatar
My front clip is intact & sitting on a dolley w/some cardboard under the edges & I'm using ratchet straps @ each side to keep it from tipping. Been there for multiple years w/o issue.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-01-2024, 09:52 AM   #10
rbruno68
Not sure what they are called but they are sort of a floor pad the fits together like a jigsaw puzzle. I think they are considered exercise mats. Either way, that is what I have mine sitting on. Thanks for the feedback. Sounds like it should be ok.
