01-19-2024, 04:41 PM | #1 |
1963 12 bolt spider gears cupped (Thrust) washer?
So I am changing the bolt pattern on my 63 rear axle. When I pulled the spider gears out of my open diff. there were no cupped washers? I wouldn't have even noticed if I hadn't watched a few Utube videos showing them being put in. I have a receipt of the rearend being completely rebuilt around 4000 miles ago. I have put about three thousand miles on the truck, no noise and the spider gears look fine? Any Ideas? Could they have NOT come with them in 63?
Thanks Last edited by transoceanic; 01-19-2024 at 05:23 PM. |
01-20-2024, 01:07 AM | #2 |
Re: 1963 12 bolt spider gears cupped (Thrust) washer?
I experienced the same discovery as you do now. I got spiders and thrust washers from another diff, so that i can go with 5x5 axle shafts i bought. When i opened rear i also saw no washers, installed washers and the other gears dont go in, so i took washers out and assemble , drove it some time now and no issues .
The 63 diff is just an oddball, had issues with seals for wheel bearing being 0.040" smaller on od . Here in south africa its really a hunt finding imperial size seals, i ended up buying metric seals and shorten the inner spring to seat id on shaft, all good so far. Cheers. Adriaan. |
01-20-2024, 11:30 AM | #3 |
I have read on the internet that sometimes they weren't used. I had a 68 rearend that had one on one side but not the other. If it's working fine I think I'd leave it alone.
If you decide you need some be careful ordering them. Some of the ones they sell don't fit because they have a raised lip on the inner ID. Related thread with source for new ones. https://67-72chevytrucks.com/vboard/...d.php?t=848797
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd |
01-20-2024, 12:03 PM | #4 |
Thanks guys, for the help. The rearend was built by a reputable shop that has retired and no longer in business so I cannot ask them? So, I assume he knew what he was doing. With that and your replies I'm going to put it back together and run it.
