Old 01-20-2024, 05:35 PM   #1
vardenafil
recomend me a radiator
i have a 1972 k20 with a 350 sbc motor. the truck has a/c and auto transmission. the previous owner did not upgrade the cooling system when he made modifications to the truck. so i have some cooling issues. im looking for a heavy duty radiator since i live in the desert. we average 115 -118 most summer days. i found two options for similar price and want to know the best option.
option #1 new copper 4 core radiator from local auto store.
option#2 two core aluminum radiator with 1.25 inch tubes.
both options will have the built in oil cooler lines.
also anybody know of a good 7 blade fan with at least 2 1/2 inch pitch for a severe duty clutch?
vardenafil is offline   Reply With Quote
Old 01-20-2024, 06:01 PM   #2
dmjlambert
dmjlambert's Avatar
Re: recomend me a radiator
I vote copper 4 core radiator from local auto store, if it's one with metal tanks. If it has plastic tanks then never mind and go for the 2 row aluminum one, but make sure it is all-weld construction and has a lifetime warranty such as Engineered Cooling Products. I suggest buy an original fan blade from for-sale listings here on the parts section of the forum, or join with a premium membership and post a want-to-buy ad. That's what I would do. Some vendors such as Manes Truck Parts and Outback Truck Parts sell used parts and you can call them and check, that's another option.
dmjlambert is offline   Reply With Quote
Old 01-20-2024, 07:09 PM   #3
adf5565
Radiator express has an aluminum 4 core, I’m sure that will do the trick.
https://www.radiatorexpress.com/prod...220879/1051445
adf5565 is offline   Reply With Quote
Old 01-20-2024, 08:13 PM   #4
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
I redid my original 3 row rad that had the 4 row tanks that was in my Factory 350 with A/C truck and made it into a 4 row rad. I don't have to deal with the the temps you do though. If I hadn't done that I probably would have got one from Cold Case Rads. There are a few board members that are quite happy with Champion Brand Aluminum Radiators. Pictured is my refurbished rad. https://www.coldcaseradiators.com/?p=login
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 01-21-2024, 02:06 PM   #5
72SB
fewer, but larger, cores are better than more smaller
look into Cold Case 2 row with 1 1/4 or 1 1/2" row. They make a nice radiator for not high $
72SB is offline   Reply With Quote
Old 01-21-2024, 11:03 PM   #6
Oldsmobuick
I've got an aluminum one from summit racing, live in the hot California climate and it works great. Looks good too. I have had some no name brand aluminum types that didn't work well, ran hot etc.
Oldsmobuick is offline   Reply With Quote
Old 01-22-2024, 11:01 PM   #7
BROWN 70
BROWN 70's Avatar
Smile Re: recomend me a radiator
x 2 post 5 I bought the direct fit for my 70gmc like it so far. chuck
BROWN 70 is offline   Reply With Quote
Old 01-23-2024, 10:15 PM   #8
Rick Bollinger
Already Gone I did mine like you did. A local radiator shop did the 4 core pinched tube also added a stacked core tranny cooler in the radiator where the original cooler line was.
Rick Bollinger is offline   Reply With Quote
Old 01-24-2024, 06:11 AM   #9
Already Gone
Now that trans cooler would have been great to do if I had thought about it.
