![]() Join Date: Feb 2003
Rear drum Parking brake cable r+r
Need to replace the rear drum e-brake cable. I assume I'll need to disassemble everything to get to the cable. Anyone have any tips or pics before I pull the drum off? Thanks! 68 c10 trailing arm 12 bolt
![]() ![]() Join Date: Jul 2003
The cable snaps into the drum backing plate, and the other end has a spring clips that retains it to the frame bracket.
1970 K/5 Blazer CST 4WD, TOTM winner December 2024! Medium Bronze poly, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD Kelsey Hayes wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion.. ![]() 1970 K20, To be a clone of my Grandfather's K20, Dark Blue poly, 350, 4 speed, 16.5" X 8.25" Kelsey Hayes wheel option, tilt, tach, vacuum, AM radio. Latest project truck 1972 Cheyenne Super 20 2WD, Dark Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... ![]() 2017 Sierra 1500 SLT 4WD, Black, 46k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 67k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
![]() Join Date: Apr 2016
Re: Rear drum Parking brake cable r+r
The conduit fingers that engage the hole on the backing plate is the only tricky part. You have to compress them all at the same time. It takes patience, mauling, cursing, holding your tongue just right, a special tool, or just small hose clamp.
https://67-72chevytrucks.com/vboard/...d.php?t=841288 |
Thanks for the help guys. Good tip on the hose clamp. I have the brake tools for the springs and all. I just didn't want any surprises when I get it in the air.
![]() Join Date: Feb 2015
Easy enough to make a new cable yourself.
Can get new cable anywhere, Ace hardware? Find a 3/8" bolt that has an unthreaded portion and cut two 3/8" long pieces out of it. Drill a hole thru that fits tight to the cable you are using. And most important, use silver solder with the proper flux to secure the nubs onto the cable. Then dip the cable ends in boiling water to remove any remaining flux. Been doing this for years with 100 percent success. |
