Old 01-23-2024, 07:58 PM   #1
K10-Kansas
K10-Kansas's Avatar
Firewall bracket for what?
Hey all, what is this bracket for? Other than holding up one side of my speaker?
1971 C10 manual cab. 76 4x4 chassis. Cut short frame. Carbureted Blueprint 350, automatic 700r4. ~ James
K10-Kansas is offline   Reply With Quote
Old 01-23-2024, 08:00 PM   #2
TxGary
TxGary's Avatar
Re: Firewall bracket for what?
Support for speaker and back of radio.
71 C-10 SWB
1969 C-30 Custom Camper Motorhome Restoration in progress.
2020 Chevy 2500 Crew 4x4 LTZ Diesel
2024 Chevy Tahoe Z71 4X4
2015 Diamond C 22' HD car hauler
Bowie, Texas 76230
TxGary is offline   Reply With Quote
Old 01-23-2024, 08:53 PM   #3
K10-Kansas
K10-Kansas's Avatar
Oh, the back of the radio somehow attaches to the bracket?
Old 01-23-2024, 09:05 PM   #4
dmjlambert
dmjlambert's Avatar
Yes, and the bracket system is not for that particular speaker you have. With GM vehicles you had to have their speaker to fit into their bracket, and back in the 70s or 80s there were no affordable speaker replacements or upgrades that fit. Nowadays you can order an exact replacement that will fit the original brackets, and you can buy used brackets here in the forum parts section and/or eBay, if you wanted to restore to original. The part of the bracket that holds the back of the radio is just for the stock radio, and the part of the bracket that holds the speaker is just for the stock speaker. https://67-72chevytrucks.com/vboard/...d.php?t=735298
dmjlambert is offline   Reply With Quote
Old 01-23-2024, 09:11 PM   #5
K10-Kansas
K10-Kansas's Avatar
Dang, this was the LMC OEM replacement supposedly. Thanks. I appreciate the info.
Old 01-23-2024, 10:51 PM   #6
dmjlambert
dmjlambert's Avatar
I didn't mean to suggest that your speaker is a bad one to have, it is probably quite a bit of an upgrade to sound. It may be tight fit for A/C ductwork and a radio up in there with that bigger speaker, but from your picture it looks like it can be done. If rear support is a good idea for your particular radio, I would imagine some generic pipe-hanger metal strap would get the job done.
Old 01-24-2024, 09:34 PM   #7
CKfan
The after market LMC speaker I got fit in the stock mounting bracket. However, the speaker magnet's shape is different from the original so it doesn't slip right into the brace like the original but it works
CKfan is offline   Reply With Quote
Old 01-24-2024, 09:38 PM   #8
CKfan
Should be a small brace for back of radio and a piece to hold you speaker attached to that piece you have shown.
Old 01-24-2024, 10:21 PM   #9
K10-Kansas
K10-Kansas's Avatar
The reproduction radio did come with a hanger wire. I'll hopefully get to put it all together this weekend.
Old 01-24-2024, 10:35 PM   #10
K10-Kansas
K10-Kansas's Avatar
Oh, thanks, I'll take a look at the parts I have and see if there is anything like that. There was a junk aftermarket radio in the truck when I bought it and I'm trying to get close to OEM as much as I can. Except for things I am deliberately not doing OEM
