![]() Join Date: Jul 2008
What are these firewall holes?
I am in the process of patching unnecessary holes on the cowl and firewall of this cab. I’m curious what the purpose of these holes I’ve circled in red.
Additionally, does anyone know the correct diameter hole for the antenna?
1965 c/10 swb 1969 c/10 lwb ![]() |
68 C10 Longbed
![]() Join Date: Sep 2006
Re: What are these firewall holes?
Windshield wiper and antenna I think.
yup,wiper and antenna.the antenna hole over on the rt side,has a big grommet on the antenna cable.
![]() Join Date: Aug 2004
That wiper hole is for RH side drive exports.
The one at the base of the A pillar is for the antenna per the assy manual. I just added that one on my cab this summer. Not sure about the one inside the cowl. It could be anything.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ Last edited by clay68c10; 01-25-2024 at 10:52 AM. |
2nd pick with two red circles: Left red circle is wiper related; Right red circle is not antenna, because I believe that hole is NOT circled by you, and is located to the left of the left-red-circle....you can see the original antenna hole. I think the right red circle is owner made.
3rd pic with one red circle: not factory, done by owner or rot. |
The Older Generation
From the Factory Assembly Manual. .
![]() Join Date: Nov 2001
Just taking a guess but that hole to the right of the wiper arm base also circle red,,, that is set back on to the firewall, is it possibly there for a clip used from the inside cab firewall to hold the padded insulation, sorry for the lack of better words, but something like a round push in clip that goes through the padded insulation through firewall to hold the padded insulation up against the inside cab firewall. It's been a while since I installed mine but I seem to remember it like that. Not a home to check.
Active Member
![]() Join Date: Sep 2023
I think we would drill an inch and 1/8 hole for the antenna base, the boss never ordered a plain truck with a radio'
David |
Thank you for all of the responses. Leon, thanks for a clip from the factory assembly manual!
What I’ve learned: -The antenna hole is home made and not in the factory location. - The factory installed wiper mounts for right hand drive (export) vehicles. -The hole on the far right is unknown and likely added by the previous owner for whatever reason.
