Old 01-11-2004, 07:48 PM   #1
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
I need GMC grill education!
I have a 70 GMC (of course) in which I just replaced my core support with one from a 68. Will my 70 grill fit the 68 core support.? My hood latch bolted on fine. Also, are 68-70 grills all the same just the 69-70 has a top bar and the 68 does not. Does a 68 use the same latch assembly? Anybody have a pic of the filler panel that goes between the core support and grill? My core support(68) has nuts across the lower front, also my grill along the bottom has holes for "j" nuts that are possibly used for the filler panel. My 70 core support does not have nuts across the lower front. Whew... Hope all you'all can make heads or tells of this, pics would be great (hood latch on a 68).
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 01-11-2004, 09:11 PM   #2
Tim Cline
The 68 Grill is the same but the top bar changed for 69 so my guess would be that the 70 grill will fit fine. The 67 and 68 had a
filler panel across the bottom between the grill and core support.
I am not sure but I dont think the 70 had this.
67 GMC SWB Project:60 4BM 350 4SPD
67 Chevy C10 Custom LWB V8 Project
69 LWB IL6 3 on tree project
71 SWB Frame off project
72 LWB C10 Factory Tilt Project.
Tim Cline is offline   Reply With Quote
