01-11-2004, 08:24 PM | #1 |
under dash wireing harness f/s
it is off a 71 $20.00 plus shipping
01-11-2004, 10:36 PM | #2 |
What equipment did this have hooked up, HEI distributor, A/C etc.......?
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
01-11-2004, 11:49 PM | #3 |
Careful, they attack...
HEI wasn't an option, and wouldn't have been involved with this harness. It's a modification you make afterwards. Same goes with A/C, it's a separate harness. The only thing to worry about with under dash harnesses is whether or not it had idiot lights or gauges. Those two harnesses are different and no interchangeable. If you have idiot lights and want to go to gauges, you need a gauge dash harness.
01-12-2004, 12:18 AM | #4 |
im interested! is it cut up bad? this is gauges right?how is the fusebox? broken? can you read the names?
70 longbed 496/th400/Ford 9" |
01-12-2004, 09:27 PM | #5 |
i think it is idiot light harness it did not have a dash bezel when i got it is there any other way to check its in good shape and you can read the box thanks bill
i have 67/72 chevy truck parts f/s. |
01-12-2004, 09:43 PM | #6 |
i already bought an idiot light harness
compare the color of the wires coming off the part that plugs into the dash with the ones on your truck if you have gauges if it is a different wiring in different order and you have guages it is a non gauges type make sense?
01-12-2004, 10:08 PM | #7 |
GMC Paul has a diagram on his site. It shows how to change a light harness to a gauge harness. It also shows the correct wire colors to compare to. It's an easy way to tell.
01-13-2004, 12:08 AM | #8 |
i checked the one i have it is for idiot lights
01-13-2004, 12:26 AM | #9 |
KEEP ON TRUCKING
is it hacked up bad is the fuse box in good shape if so and nobody else wants it ill take it if you can wait till sat/sun/mon im leaving out on truck thanks
72 cheyenne 2wd lwb 71 k20 sons bassett va |
01-13-2004, 08:27 PM | #10 |
BLUE BEARD IF YOU ARE NOT INTERESTED IN IT 72 SHADETREE IS WANTING IT THANKS BILL
