01-11-2004, 09:27 PM | #1 |
Future Owner
Vacuum and Intake Connections HELP!!
Just dropped a 350 into my 71 C10 2WD with and automatic. I will not be runnning any of the emissions crap and was hoping someone could let me know what vacuum connections i will need to make to just have all the basics work. Also any pictures and info on all the connections you made on an edelbrock preformer on a sb350 would be most helpful and appreciated. This is my first engine swap so im a little nervous. Thanks!!
Its not the end result that counts most...its the journey along the way that's most rewarding My truck doesn't leak, it just marks it's territory |
01-11-2004, 09:32 PM | #2 |
Formerly yellow72custom
Ok, you don't need very m any vaccum connections at all. You only need: Vaccum to the vaccum advance cannister on the distributor, vaccum too the transmisson modulator, vaccum to the PCV valve, and vaccum to the power brakes (if you are running them).
For the tranny modulator is ran off the vaccum fitting on the intake behind the carb. The power brake vaccum line can either be ran from the same vaccum fitting as the tranny modulator, or a from a port on the rear of your carb. The vaccum line for the vaccum advance is ran off a port on the front of the carb. There will proably be more than one, and i myself prefer to hook the vaccum advance up to the port that has vaccum at idle. Makes it idle really smooth. Just stick your finger over the port to see if it has vaccum at idle or not. The PCV will be run from a large fitting on the carb to the PCV valve. That is all you need. Hook all of it up and you should be set
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
01-11-2004, 09:49 PM | #3 |
sounds like good advice, went over his list and couldn't think of any others unless you have different equip installed.
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
01-20-2004, 01:25 AM | #4 |
Future Owner
anyone know what size vacuum lines i need for each of the connections mentioned in YELLOW's post??? Please help
01-20-2004, 09:17 AM | #5 |
Vacuum fitting sizes: 3/8" for brake and pcv
1/4" for transmission line 3/16" for vacuum advance Jim |
01-21-2004, 02:44 PM | #6 |
Future Owner
Thanks alot jim!!!
01-21-2004, 02:51 PM | #7 |
Future Owner
Thanks alot jim!!!
