Location: 3,018 feet above the SoCal/Mojave Desert region.
New turn signal switch and still nothing.
Before the truck had no turn signal lights or dash indicators.
New switch and still nothing. All fuses look good. Any ideas? Thanks. |
![]() Join Date: Jun 2002
Re: New turn signal switch and still nothing.
Pull fuse and check for continuity, or test voltage to ground on each side of fuse. Check the flasher relay if fuse is for sure good. You are turning the ignition on (sorry, I have to ask)? Do the brake lights work?
There are some good schematic links in this thread https://67-72chevytrucks.com/vboard/...d.php?t=185856
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer - https://67-72chevytrucks.com/vboard/...d.php?t=856475 '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743 Last edited by raggedjim; 02-04-2024 at 10:17 PM. |
Also check your grounds.
These truck are notorious for grounding issues |
![]() Join Date: Jan 2015
Grounds would be my guess too
#5 | |
![]() Join Date: Mar 2003
Just because it 'looks good' doesn't mean a thing. Test lamp both sides of the contacts. I've has numerous fuses that looked good over the years that were failures. Signals and dash are 2 separate circuits. Dash and running lights are the same fuse and signals work off another fuse and a flasher
I just fixed this issue also. check the plug and wiring that plugs into the rectangular box against the firewall between the steering column and fuse block. (mine was goldish color) i had no turns until i got good contact with that plug into that box. I dont know what that box is, but that was what fixed mine.
| Bookmarks |
