Old 01-11-2004, 10:49 PM   #1
Alex Hayley
relay base
I am upgrading my headlights and need to install a couple 30A relays into the circuit. I have had no problem finding the relays but cannot seem to find relay bases anywhere. Anyone have an idea as to where I might find them?
Alex Hayley is offline   Reply With Quote
Old 01-11-2004, 11:01 PM   #2
jmanz69
Careful, they attack...
jmanz69's Avatar
use female spade connectors and zip tie them together. I used to do it all the time on amp racks when we were low on bases. Works the same.
jmanz69 is offline   Reply With Quote
Old 01-12-2004, 12:06 AM   #3
Sonny
Active Member
Go to the nearest car stereo shop and they will hook you up.
Sonny
Sonny
New Project: 67 Small window SWB
2006 Crew Cab Silverado LT
Sonny is offline   Reply With Quote
Old 01-12-2004, 12:30 AM   #4
Chevy67Tk
Chevy67Tk's Avatar
Summit has them also PRF-80133 made by painless but they are a bit pricey.
Chevy67Tk is offline   Reply With Quote
Old 01-12-2004, 01:18 AM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Junk yards. New cars are loaded with relays, and the factory always mounts them. Look on firewalls, by fuse boxes, and rad core supports.
Old 01-12-2004, 02:22 AM   #6
gonebad2
Merciless Butcher
gonebad2's Avatar
I got mine from Painless Wiring. Got them when I bought the entire wiring harness. Like the guys said....You can get them cheaper elsewhere. It was just convenient at the time for me.
Your Bought And Sold....I Got Your Soul!
gonebad2 is offline   Reply With Quote
Old 01-12-2004, 02:23 AM   #7
djracer
djracer's Avatar
Car Stereo Shops for sure Or I could send you a couple! I own a mobile Car Stereo Shop.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 01-12-2004, 02:23 AM   #8
shuttermutt
Don't say "Oops!", Doctor
shuttermutt's Avatar
This might be a stupid question, but just exactly how are you upgrading your headlights and why would that require a relay?
'Mutt
1968 CST LWB: R.I.P.
1967 Chevelle: TPI 454 beast
1967 C10 SWB: Claimed when Bumpster didn't put it on his list
shuttermutt is offline   Reply With Quote
Old 01-12-2004, 02:31 AM   #9
1972C10
1972C10's Avatar
I had a friend that used to work at a car auido / stero place they had boxes of junk stuffed with all kinds of leftovers some wich included relay harnesses
I guess they hardwired them alot of soldered the wires straight to the relay other car stero shops are liable to do the same thing so you might get some freebies.
1972C10 is offline   Reply With Quote
Old 01-12-2004, 02:31 AM   #10
gonebad2
Merciless Butcher
gonebad2's Avatar
Xenon or halogen bulbs ....That's what I'm doing. The Lucas style clear ones.
Old 01-12-2004, 02:39 AM   #11
Longhorn Man
shuttermutt, just installing the relays alone will brighten up your 30 year old T-3 headlamps enough to make you wonder why you never did it before. Then once they blow out from the added voltage in a matter of weeks, you'll crap yourself with the amount of light that the plain old hallagons will put out.
Old 01-12-2004, 10:12 AM   #12
mrein3
mrein3's Avatar
I have halogens and relays supplying current right from the battery. My headlights are VERY bright.
I would do the relay swap before I spent any money on any headlight upgrades.
Plus you'll never have to replace your headlight switch again because it no longer has all kinds of voltage running through it.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 01-12-2004, 10:47 AM   #13
72BLAZERDUDE
72BLAZERDUDE's Avatar
If you got any questions about why to use relays and other assorted electrical issues try www.madelectrical.com . One of the best sights I have found. Convinced me
72 2wd 307/AT/AC/TILT WHEEL
78 JIMMY HIGH SIERRA
72BLAZERDUDE is offline   Reply With Quote
