02-12-2024, 02:41 AM | #1 |
Junior Member
Eaton limited slip differential
So if I’m to believe the sticker behind my gas tank, my 60 half ton 2WD has a limited slip. After an hour of reading old threads I think I actually know less than I did before I started. Do I have clutches in my carrier that need a posi additive? Can I run old school 80/90 weight gear oil, with the posi additive, and be OK? Does it need to be hypoid oil? I’ve yet to drive it so I don’t know what kinda shape the rear end is in, those clutches may be totally shagged by now.
Thanks!
1960 Apache10 long fleetside, 235 and SM420, Brigade Blue and Bombay Ivory |
02-12-2024, 11:49 AM | #2 |
Re: Eaton limited slip differential
You CAN run a LSD gear oil in an open diff with no problems whatsoever.
You NEED an LSD gear oil in a friction-type LSD. You do NOT want an LSD gear oil in a Helical/Torsen diff. Cheers!
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
02-12-2024, 12:41 PM | #3 |
Active Member
When I worked for Chevrolet , we had an additive that was made from whale oil that we used in the limited slip rears that had clutches in it, but that went out with the whales.
I am sure there is an additive that you can use now. |
02-12-2024, 07:48 PM | #4 |
Junior Member
Dmb, I saw that last night while reading through threads. Whales had posi!
02-12-2024, 08:06 PM | #5 |
This is what I have seen people use with no issues.
Link: https://shop.advanceautoparts.com/p/...n%20Treatments
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
