Old 02-14-2024, 10:29 PM   #1
mrhotrod69
PCV problem!
I know this has been beat to death but I’m having problems! Trying to build a clean motor. I have relocated oil fill tube to rear of intake and PCV to rear of v/c it has a baffle on inside. My problem is oil is trying to push out oil fill tube. Also does anyone know anything about breathers and oil fill in top rear of v/c?
mrhotrod69 is offline   Reply With Quote
Old 02-14-2024, 10:31 PM   #2
mrhotrod69
Re: PCV problem!
These are pics of my set up
Old 02-14-2024, 10:33 PM   #3
mrhotrod69
Re: PCV problem!
Also interested in info on this setup.
Old 02-15-2024, 09:25 AM   #4
Mike C
Mike C's Avatar
Re: PCV problem!
You may want to search over on the Corvette forum. I’ve seen this discussion over there much more than here, the C!-C2 section. Lots of guys want to run the early Corvette script valve covers but use a late model black without draft tube provisions so there are more solutions.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 02-15-2024, 09:33 AM   #5
MJN
MJN's Avatar
Re: PCV problem!
I suspect that the downward angle and bend in the PCV hose by the transmission dipstick is creating a p-trap allowing oil mist and condensate to pool and restrict the vapor/fumes from the crank case to be sucked into the intake and then the pressure is pushing out the breather. Not sure what the baffle in the valve cover looks like either or if that could be restrictive too. Also, can the pcv valve operate properly on its side?
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 02-15-2024, 01:16 PM   #6
54blackhornet
54blackhornet's Avatar
Re: PCV problem!
I like the look but not sure that it would work better than what GM engineered ? That double snout air cleaner is amazing !
71 C-20
07 Magnum RT AWD
54blackhornet is online now   Reply With Quote
Old 02-15-2024, 01:23 PM   #7
68 C10 Driver
Re: PCV problem!
I think that the way the PCV Valve has been relocated, it is defeating the functionality a little. While the relocation of the PCV makes for a clean look, but it may be contributing to your problem.
68 C10 Driver is offline   Reply With Quote
