how much to lay 22's on 67
how much would i have to notch the rear to lay my 67 on 22's. I was thinking around 10 inch. but just want to be sure. Thanx
18436572
Better make it 20. LOL
It'd be alot cooler if you did
According to my calculations (and this is for a truck with a mustang II so it will sit much lower than a "normal" truck) I'm going to need all of 11" to lay out on rubber bands. I'm getting a 12" notch.
Happy to be here
![]() Join Date: Mar 2000
What "size" 22 are you talking about running? It would help to know to get an idea of actual tire height....
///Relaxed Atmosphere
70 cut to the doors with 20's
Here is a pic of a 70 cut to the doors with 20's that laysout hard. I have seen this truck in person seveal times in person when in AZ and Cali. Put what ever size you want but the key to me is to still be able to drive and have full turning at a slammed ride height with out have the air up your ride to a getto ride. if custom did this truck and have several photo's of it in process. With 22's you need to whatch the upper body line to make sure you get off set wheels to set in far enough to not have teh tire rub the inside of the body panel when layed out or driving low.
pic to big to post here is the link: http://www.socalcustoms.com/Shows/20...s/DSC00338.htm |
I'm doing an 11inch notch with 20's - 295-40-20= 29.5 inches tall
