Old 03-11-2024, 08:33 PM   #1
850_C10
64 C10 Engine Ticking Sound Help
I started up my truck the other day and it has this awful ticking sound coming from the engine. I think it is part of the valvetrain but I am not sure. Any ideas of what it could be? Engine is a 1978 250 inline six.
Video of engine idling
https://www.youtube.com/shorts/hxsebdoDo-Y
850_C10 is offline   Reply With Quote
Old 03-11-2024, 08:59 PM   #2
dmb
Active Member
dmb's Avatar
Re: 64 C10 Engine Ticking Sound Help
sounds like a rocker arm ticking, pull the valve cover and look to see if you have bent pushrod, may just need adjusting. Did it start suddenly or get progressive louder
Old dogs and children and watermelon wine
dmb is offline   Reply With Quote
Old 03-11-2024, 10:56 PM   #3
geezer#99
geezer#99's Avatar
Sounds like a collapsed lifter!
Old 03-11-2024, 10:57 PM   #4
bhap
bhap's Avatar
You can pull the valve cover and run the engine without making too much of an oil mess. I’d pull the valve cover and look for loose rockers or stuck valves. Sometime a good dose of Marvel Mystery oil added to engine oil will loosen up a stuck lifter. Does it look clean or dirty if you look in the oil filler hole?
bhap is offline   Reply With Quote
