Old 01-12-2004, 01:35 PM   #1
Porkchop
Porkchop's Avatar
73-87 posi on a 69
Will a 73-87 (I don't know the exact year of the truck) rearend fit onto a 69 truck. Is it too narrow.
Thanks alot
brad
Porkchop is offline   Reply With Quote
Old 01-12-2004, 09:12 PM   #2
1972C10
1972C10's Avatar
The rear will work but you will have to put all your brackets on it and fab up a panhard bar bracket i think the newer style is about 1/2 wider than the 69 there ident to a 72 as far as width
1972C10 is offline   Reply With Quote
Old 01-14-2004, 01:52 PM   #3
Porkchop
Porkchop's Avatar
Would I be able to use the leaf springs from the 79 on my truck? (I found out that that is the year of the truck)
thanks for the help
brad
Old 01-14-2004, 05:31 PM   #4
1972C10
1972C10's Avatar
I dunno i suppose you could put leaf springs on the frame of the 72 jsut as long as you get them sqaure its alot of work i had a friend to put leafs on an old truck once he had to customfy some brackets to get them sqaure because of the was the frame was shapped.
I was talkin about putting just the rearend in and welding the coil spring brackets to it isnt really all that difficult just gotta get it sqaure.
Old 01-14-2004, 05:39 PM   #5
Porkchop
Porkchop's Avatar
Ohhh, my truck is a leaf sprung 69. I noticed that I didn't even mention it was a 3/4 ton. I was in a hurry that day.
I was thinking that I could just remove the leafsprings from the half ton and put them right inplace of the 3/4ton springs. Maybe I could even swap the brackets. The reason I want to do this is so that the truck will sit lower.
thanks for the help
brad
Old 01-14-2004, 05:42 PM   #6
J.Lance
Too many is never enough!
springs
I don't believe the spring pads are the same width on the rear ends nor do I believe that the leaves are the same length. If you have the resources, it is not too difficult to relocate new pads and shock mounts on the new diff and it might be easier to find some 69-72 1/2 ton 2wd leaves to swap in.
Jason
1968 K10 SWB Fleetside
1971 K2500 GMC LWB
1968 K20 (later frame, donor body)
1972 C20 LWB parts truck
1993 K2500 Suburban, tow rig, 454, 4L80E
NEW!! 18' Siem's car hauler
2004 Honda Odyssey (family man!)
J.Lance is offline   Reply With Quote
