Ok, I can get a entire rear end from a mid to late 90's Caprice from the local bone yard for $150. It has rear disks. I have read that you can use the rear rotors on a 12 bolt, but can the entire Caprice rear disk set up be used on a truck 12 bolt? Will the backing plates bolt to the truck rear end? The Caprice is kinda buried in the dirt so I really can't get any measurments that would be any good to find out. Plus $$$ is real tight right now, so I don't wanna end up with a $150 boat anchor sitting in my garage.
TTT
member #16
![]() Join Date: Dec 1999
There is some caprice info and pics in this thread.
http://67-72chevytrucks.com/vboard/s...ar+disc+brakes
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
I have seen that thread. That is how I know that the Caprice rotors will fit. I was wanting to use the Caprice backing plates though, so I can use the Caprice parking brake, and be using all GM parts.
The Caprice backing plate will not work on a 12 bolt. The axle tube on the Caprice rearend is smaller and the bolt pattern for the backing plate is different.
Here is a picture of my rear disc brakes.
383 Stroker, what did you use for brackets? I can get cailpers and rotors at work, so reallythe only thing holding me is a bracket set-up. I do need a parking brake though. Hhhmmmmmmm. . . .
I made the backing plate out of 3/8" steel.
