Don't say "Oops!", Doctor
Is the stock gear indicator on the column of an automatic truck supposed to light up in any way? Just curious.
'Mutt 1968 CST LWB: R.I.P. 1967 Chevelle: TPI 454 beast 1967 C10 SWB: Claimed when Bumpster didn't put it on his list |
Resident Curmudgeon
![]() Join Date: Dec 1999
Yes. If non-tilt, there is a fibre optic line that runs from a bulb on the cluster by your speedo down to the pointer.
On a tilt, it is electric and the column has an additional wire that needs to be plugged into the "cluster" spade on your fuse box.
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter ![]() Maybe I need to sell some of this crap ![]() Yet another Bozo with a sawz-all |
Are those fiber optic cables repairable, or does anybody sell new? When I disassembled my column, I noticed mine has a hole in it from being pinched in the column.
its all about the +6 inches
I don't think they are reparable, and I am pretty sure no one is making them.
PM me if you need one. |
i didnt know they suppossed to light up either.guess ill have to look into that myself.
springfield illinois 2003 custom (harley)built from scratch 68 swb Last edited by doughby82; 01-14-2004 at 04:19 AM. |
Does the tilt-column light use a bulb? I have a nice used [tilt] column that I plan to install. I wonder if the light and wiring is still inside the column? Hmmmm? I guess I should take a look-see. My non-tilt column [light] has never worked. I didn't even know there was supposed to be a light. I have never seen one that had a lighted indicator. Just when you thought you knew all about these old trucks- you learn something new! Thanks guys! Something else to get working.
Terry ![]() ![]() |
Yes, the tilt has an actual light bulb in them. When you plug in the harness, you'll see a single gray wire dangling down there, plug that into the fuse box where it says lights, or inst lights...something like that, then the light will turn on and off with your dash lights.
My other Love
fibre optic is non repairable, the way it works is the fibre optic line goes into ome of the sockets for the dash lights
![]() Castlegar B.C.The great white North (Canada Eh!) Hooter_5@hotmail.com First generation Monte Carlo club pictures of my life |
#9 | |
C/10 CLUB MEMBER
![]() Join Date: Jul 2003
-Ron- ![]() |
Thanks Longhorn Man!
I'll have to look to see if the light is still in the column. It sure would be nice to have that working. Terry |
#11 | ||||
Resident Curmudgeon
Post #2
Post #6 Quote:
Isn't there a joke circulating about how many board members does it take to screw in a light bulb? Classic! ![]()
2A674 Tank Rat
And I thought thats what the dome light was for.
'92 GMC Sierra, Sportside, 2wd, 350, Black '92 Chevy Silverado Extended Cab 4 x 4, Blue USAFR = 2A674 = Aircraft Fuel Systems Maintenance i.e. Tank Rat |
#13 |
Pennyless Fool
Wow, I had no idea. My indicater thing looked solid. I just took the lense off and looked, theres another clear lense and little hole in there. Learn something new here everyday! Guess I have to climb under there and try to trace this fiberoptic thing now.
"Who owns this car with the peace sign, the mag wheels, and four on the floor?" 67 Short Step 283/TH400/4.11 |
#14 |
fiber optic cable 10.00 shipped
FIRST COME FIRST SERVED....ONLY HAVE ONE.... P.M. IF NEEDED MARK ![]() |
#15 |
Re: Auto tranny gear indicator light
wow... 3 years and 2 months!
PM me as a reminder (I'm headed out to worh in a sec) and I'll take a look see if I have a socket for you there Woogeroo |
#16 |
Mine works, but I will admit I never knew it used a fiber-optic cable. Good Info!!
1969 ![]() ![]() |
#17 |
The Fiber optic cables are reproduced. p/n 3276689
http://www.gmcpauls.com/new_products1.htm The fiber optic bulb socket for the dash was just dicontinued by GM p/n 6288601
71 Chevy CST Long Fleet 350/350/3.07 leaf rear. Last edited by 71Chev; 03-19-2007 at 11:44 AM. Reason: socket info |
#18 |
I always wondered what that funky tab on the bulb socket was for.
Now i Know, and knowing is half the battle ![]() ![]()
2003 GMC Sierra 1500 WT 1995 Nissan Hardbody 2016 Hyundai Veloster Turbo DC2 (SW/AW) Clyde W. Harvey USN "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill |
