Old 03-19-2024, 09:03 AM   #1
adf5565
K30 Aftermarket Rim Center Cap Mod
Has anyone modified (successfully) a center cap on an aftermarket rim to fit over a K30 Dana 60 front axle hub? I recently purchased Black Rock Series 942 Type D rims for my K30.
I am fine with leaving the caps off if needed but figured since I have them if I could cleanly make them fit I'd try it. The OEM hub caps had the center hole to fit over the hub.
If anyone has done this before and could share pictures or method you used it would be appreciated.
adf5565 is offline   Reply With Quote
