Before and After
Stain / Protecting wooden boards
I have my wooden bed boards stained, and plan to clear coat them. Do you think 3 coats of exterior grade Marine Varnish will be enough protection?
The can says: Thin first coat 10%, apply a generous coat, a second coat should be applied 8 - 12 hours later. A third coat can be applied if desired. I think three coats will be sufficient. I have the boards all cut, grooved, and drilled before I stained them. Is there anything that I should be aware of before I start this process? I would hate to screw up the oak boards before they are in place.
Not Grandpa's C-20 anymore... 383 Stroker 425HP, 485Ft/Lbs Lowered 3.5" Front / 5" Rear 66,000 miles. Alberta, CANADA |
I would rub them down with steel wool or a scotch brite pad , then clean with a tack cloth between coats.
