Old 05-18-2024, 02:49 PM   #1
Luke87gt
Common Manual Transmission Options with LS Engine?
Hi guys,
What are the common manual transmission options that the LS guys are using these days? Following would be important:
- 5 or 6sp (6sp preferred)
- can be pulled off an oem vehicle for simplicity/cost
- commonly utilized with LS swaps
- budget friendly always a plus
I haven’t decided what direction to go (keep 250 i6, swap takeout 350, BP 396+, or just go straight to LS which is something I’ve always wanted to do - LS3 or L33 based).
Thank you
1969 C10 Shortbed
Luke87gt is offline   Reply With Quote
Old 05-18-2024, 03:19 PM   #2
Rust_never_sleeps
Rust_never_sleeps's Avatar
Re: Common Manual Transmission Options with LS Engine?
There aren't a lot of practical arguments against the LS swap.
Most of the reasons to stick with an older motor are because it's fun to tinker with something different, or for nostalgia
1970 C10 Custom longbed 350/350
Rust_never_sleeps is offline   Reply With Quote
Old 05-18-2024, 04:34 PM   #3
hewittca
hewittca's Avatar
I am in to see what transmissions everyone suggests. When I built my truck with an LS swap I went manual transmission with budget being the limiting factor. This lead me to the NV3500 out of an early 2000s Blazer. I was able to pull the transmission from a junkyard for a couple hundred bucks. All I did to it was clean it up and change the trans fluid. I used all standard GM components for the flywheel, clutch, throwout bearing, and master cylinder. This transmission is sufficient for a straight up "junkyard LS swap" where you basically run the engine with no power mods. It's also a truck transmission so you definitely get to row some gears. For getting my build moving under its own power I am happy with this transmission, however, I do wish I had something a little more durable that I could beat on every once in a while.
Builds: Green Gus the 68 C10 ; Sullii the 72 1500
Instagram: @dr.hewitt
C10 Concept/Development Photos: Master Thread
hewittca is offline   Reply With Quote
Old 05-18-2024, 05:19 PM   #4
LS short box
I've used both a TKO 600 5 speed and Tremec 6 speed in a couple projects. Both worked worked well.
I think hot set up today is the TKX 5 speed. Fits the trans tunnel better due its more rounded on the top. And rated for some pretty good power.
I tend to over build stuff. Planning for future power mods.
Other thing to consider is your tire diameter and rear gear ratio.
On my 68 C10 with the 6 speed I ran 20" wheels/tires and 4:10 gears. Unless I was on the free way I never had to use 6th.
LS short box is offline   Reply With Quote
Old 05-19-2024, 02:41 AM   #5
Luke87gt
Thank you
What about a run of the mill t56 pit of an Fbody Camaro?
1969 C10 Shortbed
Old 05-19-2024, 09:35 AM   #6
PbFut
Pretty much anything will fit. You need to decide if gearing is in your range of needs. The tremic trans are hard to beat. Very strong and lots of shifter position options. You can even bolt up a old Muncie if you want. It requires a correct bell housing but you can use a mechanical clutch. I don't know if there is a mechanical option for the newer typical LS bolt on trannys. You might have to do a mod to go hydrolic. I put a Jerico dog box, (think Muncie 4sp.) behind a LS2 with 7" clutch and flywheel in a BMW. Anything is possible with enough will to figure out the needed combos.
PbFut is offline   Reply With Quote
Old 05-19-2024, 10:40 AM   #7
KQQL IT
At the body shop.
KQQL IT's Avatar
Tkx in a 56 bel air for a future LS activities.
Fit like it belongs there.
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is offline   Reply With Quote
Old 05-19-2024, 10:55 AM   #8
CAMAROBOY68SS
CAMAROBOY68SS's Avatar
Originally Posted by Luke87gt View Post
Thank you
You just have to watch your shifter location on a F body unit. They are set really far back with no real option to move them forward like a aftermarket Tremec and I think you will need a high hump for that one.
I stuck a new TKX in my truck this winter along with a new small block. I had a car Muncie 4 speed prior. The TKX fit perfect with the low hump and the hole where my old shifter fit was almost dead on with the TKX, needed a little trimming, but I didn't need to move my boot at all.
The Twins:
1968 C10 SWB - Blue 327/5 Speed
1968 Camaro SS/RS - Blue 327/4speed
C10 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=833278
The "Others"
1933 Ford Pickup (Camaro in disguise)
2017 Camaro SS
Life long Chevy guy
CAMAROBOY68SS is offline   Reply With Quote
Old 05-19-2024, 03:13 PM   #9
72SB
OP
LS/TKX is basically the go to combo for older cars/trucks. The Magnum is a 6 speed and does have a forward shifter position, but you likely would need to raise tunnel as its a big trans
IDK if Silver Sport or American Power Train make a conversion kit for the C10. I bought my T56 from D&D performance for another, non C10, auto to stick swap if you are just shopping for a Tremec. D&D are about the largest Tremec dealer.
72SB is offline   Reply With Quote
Old 05-19-2024, 04:37 PM   #10
LS short box
There is a guy on this forum "Captain Fab" that I bought the hydraulic clutch parts from for my T56/LS6 swap in my 68 C10.
I used a LS7 Corvette clutch/flywheel kit. 2002 Camaro slave cylinder. Tick speed bleeder. ARP flywheel bolts because the bolt diameter is an odd ball size.
2002 Camaro bell housing. High hump trans cover.
Worked perfect.
Pic of the shifter tower coming thru the floor. Pic of the fire wall with clutch master.
My .02 on a used 2002 T56? Unless the seller can show receipts for a recent total rebuild by a known trans builder I wouldn't touch it.
Old 05-19-2024, 05:20 PM   #11
72SB
yeah any used modern manual trans....your Mother was not likely the P.O.
Old 05-20-2024, 07:57 PM   #12
Pick8208
Pick8208's Avatar
Another vote for the TKX. It's like a TKO that has the shift feel of a Magnum/Super Magnum/T56. Stout and small. Good for 600 lb-ft. Several ratios available.
Check with Silver Sport. I used their 67-72 C10 kit behind the 6.0 in my ’67, which included a front-mount shifter, new pedal, clutch and flywheel, bellhousing, the hydraulics and the crossmember/mount. The kit included break-in oil for the trans, regular oil to be swapped later and DOT4 fluid for the clutch.
Their reproduction 621 bellhousing has the provision for a mechanical clutch, too. All of it would fit under a low-hump floor in the C10 — but I swapped to a high hump anyway...
Jim
1967 C20/C10 shortbed LS/TKX
1979 C10 LS/T56 (Sold)
1966 Caprice 468/TH400/EFI
1968 Camaro
Pick8208 is offline   Reply With Quote
