Old 05-31-2024, 10:39 AM   #1
64stpside
Opinions on loading suspension before torquing
I did a complete overhaul on a 1990 gmc s15 jimmy i had yrs ago and before i disassembled everything, with the tire still on, i took a measurement from the ground to the bottom of the lower control arm. After swapping everything, I raised the floor jack under the control arm to that measurement and torqued the control arms to spec. The jimmy had rubber bushings in the control arms and i didn't want to stress the rubber bushings when jacking up the control arms up with them being tight already.
Should I do this on my 64 c10 or being it has metal bushings, I don't have to worry about it?
64stpside is offline   Reply With Quote
Old 05-31-2024, 03:04 PM   #2
SkinnyG
SkinnyG's Avatar
Re: Opinions on loading suspension before torquing
I have not done the metal bushings, but I do not "load" the suspension when torquing polyurethane bushings - the bushings slide, not twist, so the loading is irrelevant.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
