Old 05-31-2024, 11:54 AM   #1
scott123
Body mount/bolt locations
I made a dumb mistake. The previous owner welded just about everything on this truck, not only the body bolts to the cab floor but ran a bead along the threads after tightening the nut.
I should have measured before I cut them out. (not smart)
Should i roll the chassis back up under with the new mounts and then weld in the patch panels to align with the frame mounts? or....
is there a diagram showing measurements from a reference point to the body hole in the pan?
I moved a bit fast on this one.
Scott
scott123 is offline   Reply With Quote
