Old 05-31-2024, 05:48 PM   #1
Loose Screw
Loose Screw's Avatar
Edelbrock Intake Bolt Socket...What You Using?
I got all sorts of funky sockets but none fit. I see size 12mm, 12 point flange bolts mention on the Worlwide Web. Is that what I'm needing? And where'd you get yours?
Thanks!
Loose Screw is offline   Reply With Quote
Old 05-31-2024, 06:00 PM   #2
Accelo
Accelo's Avatar
Re: Edelbrock Intake Bolt Socket...What You Using?
I assume you are referencing a SBC.
If this is the case, the bolts are not metric they shouild be 3/8" NC. I have never seen metric bolts with English threads or English bolts with metric heads. Sockets come in 6 or 12-sided formats. I suspect 3/8" or 7/16" 12 point socket should work for you?
Accelo is offline   Reply With Quote
Old 05-31-2024, 07:01 PM   #3
Loose Screw
Yep 350, Look like these....
Name:  Edelbrock Bolts.JPG
Old 05-31-2024, 07:10 PM   #4
72c20customcamper
72c20customcamper's Avatar
Should be 3/8 or 7/16 12 point depending on brand you can use a socket or a box end wrench. Now if they are on a later like 90 and up model v8 they could be metric
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 05-31-2024, 07:32 PM   #5
Steeveedee
Who Changed This?
Steeveedee's Avatar
Those look sort of like the heads on bolts the Deere started using on tractors in the '70s. It's been awhile, but I seem to recall that 12-point sockets didn't work on them. Or maybe us old guys only had 6-point sockets? Memory is a fickle thing.
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 05-31-2024, 07:36 PM   #6
HO455
Post Whore
HO455's Avatar
I just pulled an intake off a Pontiac that had those bolts installed. Cheap junk! They when straight from the engine to the scrap barrel. They were 5/16-18 threads
There was no consistent size for the heads. I ended up using a 3/8" six point for some and had to use a 10mm 12 point wrench for others and a six point socket to get the rest out. ABSOLUTE GARBAGE!
RIP Bob Parks.
Old 05-31-2024, 07:39 PM   #7
72c20customcamper
I’m sure it depends on the brand . Never have had a problem with ARP brand I use them on headers and intakes .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 05-31-2024, 08:22 PM   #8
Loose Screw
Seems to me I already went in there with those, that's really common. That's only one step up from a hammer and screw driver in any knuckle busters tool box...but I might of been trippin l'll look at them again...
Old 05-31-2024, 08:23 PM   #9
Accelo
Accelo's Avatar
There is such a thing as a reverse Torx. Maybe that's it?
https://www.amazon.com/SEDY-14-Piece...2&gad_source=1
Old 05-31-2024, 09:02 PM   #10
72c20customcamper
Try 5/16 a picture of the actual bolt your dealing with would help
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 06-01-2024, 01:13 AM   #11
Rust_never_sleeps
Rust_never_sleeps's Avatar
Those look like External Torx, aka "e-Torx" aka "external star" aka "E-sockets"(I wish I were joking)
I picked up a small set from Harbor Fraught because I needed them for a Jeep 4.0.
They're easy to find in most brands...once you figure out what to call them :-\
....Accelo beat me to it, I just didn't see their post
1970 C10 Custom longbed 350/350
Code:
            __
     ______|__]\____
....|___(o)_____(o)_]
Rust_never_sleeps is offline   Reply With Quote
Old 06-01-2024, 09:05 AM   #12
Loose Screw
Thanks Guys I have All the different variables of Torxs...I got to get back out there and try this again......
and you know I sleep eazy because when worse comes to worse I got a good collection of Vise Grips! Good Ones not Pittsburghs!
Old 06-01-2024, 12:58 PM   #13
MikeB
MikeB's Avatar
I just pulled an intake off a Pontiac that had those bolts installed. Cheap junk! They when straight from the engine to the scrap barrel. They were 5/16-18 threads. ABSOLUTE GARBAGE!
A long time ago I ordered a set of Summit-branded intake manifold bolts that were cheesy like that. But since then I've used nothing but ARP stainless bolts, both 12- and 6-point that take a 3/8" wrench. I recommend using the flat washers that come with the bolts.
I also use ARP's 6-point header bolts that are great for tight spaces where you can only use a open end wrench. They even sell a set with 5/16" hex heads.
Over the years, I've acquired a few ARP stainless bolts that I use for other applications like this:
Mike
1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- converted from 250-six to roller cam 350, Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 06-01-2024, 07:27 PM   #14
Jim Boy
What's a guy supposed to do, put a hitch on his tool box and take it with him in case there is a problem. My opinion is if you get them out bury them 6 feet under and go back to basics. I'm too old to change and I now know why a mechanic has 6 tool boxes. They are like my dad as he was a millwright and his spending on tools cost him the marriage. Sleep tight eh!
Jim Boy is offline   Reply With Quote
Old 06-02-2024, 01:00 AM   #15
Rust_never_sleeps
<<and you know I sleep eazy because when worse comes to worse I got a good collection of Vise Grips! Good Ones not Pittsburghs!>>
There's always the redneck socket set, commonly referred to as a pipe wrench
Code:
            __
     ______|__]\____
Old 06-02-2024, 11:41 AM   #16
Loose Screw
Why did the Engineer/Tool Maker/Scientist create the 12 Point Socket?
"Why do they make 12 point sockets?
The additional points make these sockets easier to connect with the heads of fasteners. This is ideal if you are trying to work on a fastener that is hard to see or you cannot see at all. 12 point sockets are also great for use in tight spaces as they allow you to connect to a fastener at more angles.Aug 21, 2019
6 Point Sockets Vs 12 Point Sockets - Which Should You Use?"
tengtoolsusa.com
And then there's the guy who invented the 12 Point Head Bolt...
***Yes Folks, I went out and looked at these Edelbrock intake bolts Again and they do take a 3/8" 12 Point socket or wrench!***
The older I get the more glitches I find in the Matrix!
Old 06-02-2024, 11:52 AM   #17
54blackhornet
54blackhornet's Avatar
Why did GM not use lock washers on intake bolts ?
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 06-02-2024, 11:57 AM   #18
MikeB
MikeB's Avatar
Every now and then, I'll run into something that I don't have a wrench for. Last week it was a Schrader valve assembly with a hex head that measured around .610", so a 5/8" wrench was too large and a 15mm wrench was too small. Doing the math, even a 19/32" or 21/32" wouldn't have fit. Ended up using a crescent wrench.
I've also seen bolts and bleeder screws with threads that are neither metric or SAE. Those were made in China using non-existent standards or QA.
Mike
Old 06-02-2024, 12:03 PM   #19
Loose Screw
aaand just for grins we have GM's Clutch Head....
Old 06-03-2024, 12:47 PM   #20
Steeveedee
Who Changed This?
Steeveedee's Avatar
^ I still have clutch head screwdrivers, as I have been wrenching since the '60s.
~Steven
Simi Valley, CA
Old 06-03-2024, 12:50 PM   #21
Cali72K20
Cali72K20's Avatar
I had the same issue with an Edelbrock bolt kit, I have the Craftsman version of this:
Powerbuilt 3/8-Inch Drive Universal Socket Set, 7 Piece, Fits SAE and Metric, Size Markings - 642054
HF has them too:
https://www.harborfreight.com/7-piec...set-96809.html
Cali72K20 is offline   Reply With Quote
Old 06-03-2024, 03:10 PM   #22
Loose Screw
HF has them too:
Yeah, I'll order a 3/8 set from Amazon or somebody, but that's looking like exactly the tool for those bolts. The 12 point socket did work for me but I had to have them on there just right or it was a Head Stripper/Knuckle Buster.
Thanks!
Hope this helps other wayward shade tree mechanics!
Old 06-03-2024, 03:47 PM   #23
Loose Screw
HF has them too:
Damn......and going down the primrose internet path I see where Home Depot is calling something similar a "Knurl Grip" socket...
I'll go with "Spline"!...from Amazon...15 bucks....Harbor Freight a little to big, but I'll look at them anyway.....
