Old 06-01-2024, 09:47 AM   #1
twoskies
twoskies's Avatar
Windshield gasket
Morning
Got a 66 c10. That I’ve replaced the inner roof and the outer front upper panel
I replaced the inner roof first. Leaving the outer front panel in place for reference
Then when I was ok with the fit. Welded the inner roof in place
Then with the inner roof stable.
Cut and replaced the front outer roof section in
I want to be sure I have not changed the pinch seam
I’m trying to put a windshield in to check. New gasket
Here’s the problem
I can’t get the gasket to start I’ve watched several videos. Some use glass cleaner some use soapy water some use nothing
Including two pictures. Assuming the small opening goes to windshield bigger goes to outer around the frame. Makes sense
I’ve left outside in driveway for a few hours. No difference
Might try a heat gun
Thanks for any help
A Little Better Every Day
Cancer Survivor, most dont know what they have until its gone, appreciate everything
twoskies is offline   Reply With Quote
Old 06-01-2024, 09:36 PM   #2
Wrenchbender Ret
Re: Windshield gasket
First use a high quality gasket like "Steele Rubber". I had a glass man put mine in after I bought the windshield & gasket. He was amazed how much better it fit & easier to install then the cheap ones he had been using.
Also silicone spray will be the best lubricant but if you are going to paint anything around there in the future don't use it. It will ruin a paint job.
George
Wrenchbender Ret is offline   Reply With Quote
Old 06-02-2024, 04:23 PM   #3
slorio
slorio's Avatar
Twoskies:
I used white lithium grease after my glass guy gave up...
Read all about it here:
http://67-72chevytrucks.com/vboard/s...d.php?t=833869
Regards
Steve
New Orleans
slorio is offline   Reply With Quote
Old 06-02-2024, 09:27 PM   #4
twoskies
twoskies's Avatar
Hey
Thanks for the replies
I got it. Had to use a plastic knife on both sides. But it worked
Got the rope in
Waiting a couple days to install
