Old 06-02-2024, 12:55 AM   #1
howzzzit
howzzzit's Avatar
No front brakes
Driving a 72 C10 with stock front disc brakes and drum rears. Haven't changed the front pads for years so I decided to do just that. When I pulled off the pads they looked new with no wear. The piston was still pushed in like I would have done before installing new pads. This is both front brake sides. Apparently I've only been stopping on the rear all these years. What should I be looking for?
Another note. No brake light is coming on. Checked brake light switch and it's working working properly. All panel bulbs new. Both front sides have the same symptoms so I would think it's either the master cylinder or combination/proportioning valve. Proportioning valve is centered. Guess I'll change both so I only have to bleed once.
howzzzit is offline   Reply With Quote
Old 06-02-2024, 01:05 AM   #2
franken
Re: No front brakes
There's a valve in the lines by the master cylinder that makes fluid go to the front or rear when one end loses pressure. There's a little tool you're supposed to use when bleeding to keep the pin from moving.
http://67-72chevytrucks.com/vboard/s...d.php?t=785770
franken is offline   Reply With Quote
Old 06-02-2024, 01:15 AM   #3
Rust_never_sleeps
Rust_never_sleeps's Avatar
Re: No front brakes
At least they never squeal
1970 C10 Custom longbed 350/350
Rust_never_sleeps is offline   Reply With Quote
Old 06-02-2024, 01:45 AM   #4
howzzzit
howzzzit's Avatar
Re: No front brakes
I did use that tool recently. I had to replace a rear cylinder. Years ago when I replaced the pads I wouldn't have needed to bleed the lines.
Old 06-02-2024, 11:18 AM   #5
yuccales
yuccales's Avatar
Re: No front brakes
A new set of rear drums and shoes! In all seriousness, you'll get it all worked out.
yuccales is offline   Reply With Quote
Old 06-02-2024, 12:12 PM   #6
truckster
truckster's Avatar
Re: No front brakes
Check the hoses. In fact, after so many years, I would just change the hoses.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 06-02-2024, 01:52 PM   #7
howzzzit
howzzzit's Avatar
Re: No front brakes
Well, took it for a ride. Slammed the brakes a couple of times. Front working now. Must have been the proportioning valve. We'll see. Thanks for the help.
Old 06-02-2024, 02:06 PM   #8
weq92f
weq92f's Avatar
Re: No front brakes
It must feel WAY better now. Put a lot of heat into the pads/rotors by stopping hard several times to bed the pads and season the rotors...then it'll feel even better.
-Kevin
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
