Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 06-05-2024, 09:56 PM   #1
Ricks1971
Ricks1971's Avatar
installing lights for under dash gauges
Hey guys In installed after market under dash auto meter gauges (oil pressure and water temp) The gauges have lights and I would like to hook them up to my headlight switch on my 67 C10 as I don't want to hook them up to a toggle switch? any help would be great thanks Rick
Ricks1971 is offline   Reply With Quote
Old 06-05-2024, 11:02 PM   #2
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: installing lights for under dash gauges
Find the PNL LTSW fuse on the fuse panel and splice into the gray wire that comes off it. There should be an input green wire to the fuse That comes off the headlight switch rheostat for dimming of the lights. It is not fused so the gray wire is the one you need. You might consider upgrading the fuse to a 4 or 5 amp. There are other ways to do this, but I think this is the easiest.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 06-06-2024, 10:08 AM   #3
Ricks1971
Ricks1971's Avatar
thank you
