Old 01-13-2004, 04:03 AM   #1
casey
casey's Avatar
diff illiterate
I'm sure this is a dumb question but can someone explain the advantages to theses rear diffs I know there more heavy duty, they look the same as my front 4x4 diff,why do they carry more weight than a regular diff? is there a gear on the out side to turn the hub?hope you don't mined Landon I'm using your pic for an example, I don't know anything about theses diffs never had nothing to do with them in all my years
casey is offline   Reply With Quote
Old 01-13-2004, 04:06 AM   #2
72 CustomCamper
huh ???
72 CustomCamper's Avatar
That axel called a full floater uses twin bearings like the front axel. The weight of the truck rides on them. A standard or semi floating axel the weight of the truck rides on the axel shaft and single bearing...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 01-13-2004, 04:14 AM   #3
Rooster's 67
Rooster's 67's Avatar
the hub can be left on the housing while the axle can be unbolted from the hub and removed from the housing to replace a broken axle for example.
they are also an oil bath design on the bearings the housing is filled high enough with axle grease that the bearings run in lube.
The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself?
Rooster's 67 is offline   Reply With Quote
