Whats this?
Putting the truck back together and cant remember where this goes ?? I think the heater which is why I cant figure it out. The heater isnt going back in
Re: Whats this?
My guess would be an antenna cable for a radio.
My 57 Chevy truck build.http://67-72chevytrucks.com/vboard/s...d.php?t=541132 |
Re: Whats this?
me too, thinking it's a radio antenna coax cable. broken by the look of it. possibly just scrap.
Re: Whats this?
Yup. The the funny looking hardware on the end gets pulled up tight under the fender by the antenna nut to give a good ground.
55 Cameo w/ 409/700r4 |
Re: Whats this?
Thank you
Re: Whats this?
That's a strap to hold the muffler up so it doesn't drag on the ground!!!!
Take Care Troy |
![]() Join Date: Jul 2007
Re: Whats this?
That antenna cable escaped the trash barrel until to day with effective hiding techniques.
Re: Whats this?
Multi purpose part!
Re: Whats this?
That still might work if you can find the mast and the fittings that go on top of the cowl/fender.
There should be a rubber base gasket, plastic piece that looks like half of a ball with an elongated hole in it, a chrome piece that goes over that, a chrome nut that screws on the piece you showed and then the antenna mast.
#10 | |
Re: Whats this?
Re: Whats this?
I'd put it all back together in one unit and if it didn't go back on the truck there is always some rig that will need an antenna at some time. Or put it in the 2.00 box for the swap meet.
| Bookmarks |
