Old 06-10-2024, 11:29 PM   #1
Justin71105
Brake pedal return spring - 64 C10
Have found some posts on this but none of them list where they found a spring that works.
It looks like I need a 5" spring with ome of the hooks a little longer than the other side, found some prospects on lowes website. Don't know how strong it needs the be, the one I am looking at is probably going to be too much at 40lbs.
Had anyone found a good options, online or a common hardware store. Will hit up tractor supply and ace hardware to see if they have something that could work.
I do have the parking brake spring that voes under the truck I may try to cut down and use.
Have searched online and none of the normal sites I have used list ome, classic parts, lmc, brother, etc...
1964 C10 Rusto-mod
5.3L - L59 Flex Fuel
BTR Truck Norris
Justin71105 is offline   Reply With Quote
