Old 06-13-2024, 03:00 PM   #1
oneshotkyle
Sold……68 inline 250/th350 complete runner
Complete running Chevy 250 inline 6 cylinder out of 68c10 pickup. Rebuilt at some time has brass freeze plugs. Mileage unknown but cant be much. Starts and runs as smooth as they come. Completely re-sealed valve cover, lifter covers, timing cover, oil pan. Used new grade 8 bolts in everything. New water pump, 160 degree thermostat, mechanical fuel pump, HEI distributor, plugs, build to fit plug wires, 1 wire 65 amp alternator, ebay polished 1 barrel carb w/electric choke, 153 tooth flex-plate, high torque starter and 7 blade clutch fan. Custom made fuel and vacuum lines. Turbo 350 rebuilt with a stage 2 shift kit. This is a running package and can be driven before purchase. It is currently in a 68c10. Could be sold with new radiator, shroud and hoses additional. I also have a Saginaw 3 speed with bell housing and correct starter for that. And a new 11” clutch and flywheel.
2800.00
Looking for Holley Pro Dash 12.3”, OEM tilt column for 67-72 truck, Boyd rear mount fuel tank for 67-72. Other trades consider
oneshotkyle is offline   Reply With Quote
