Old 01-13-2004, 10:13 AM   #1
smokekiki
Mike
smokekiki's Avatar
Brake problems
My right front caliper keeps locking up under moderate braking.The suburban has a new master cyl.The right caliper is hard to bleed.It takes a lot of force to pump the brake when bleeding,even with the bleeder backed out a couple turns!Time for a rebuild,or could it be the proportion valve?I never had a prop valve go bad.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 01-13-2004, 10:37 AM   #2
MOTHERTRUCKERS
Sounds like the brake hose to me, they collapse on the inside.
Rest in Peace Ed. Thanks for all the good times.
MOTHERTRUCKERS is offline   Reply With Quote
Old 01-13-2004, 10:44 AM   #3
smokekiki
Mike
smokekiki's Avatar
It has 2yr old braided stainless hoses on it.It is a 4x4 with a 3"lift.I put the hoses on .
Old 01-13-2004, 11:44 AM   #4
smokekiki
Mike
smokekiki's Avatar
The proportioning valve on my burban is from a '77 and has a bleeder screw on it.I bled the prop valve and bled the calipers again.When I step on the brake with the lid off the master cyl'brake fluid shoots stait up and hits the underside of the hood.This is only from the chamber for the front brakes.
Old 01-13-2004, 11:48 AM   #5
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
bleed the prop valve then try to bleed the calipers again but im really thinking its the line. Some parts fail early dont matter how old the lines are. only other thing that would make sense is that the caliper itself is full of garbage and is jammed, but 9/10 of the time its the line
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 01-13-2004, 04:23 PM   #6
smokekiki
Mike
smokekiki's Avatar
I put new calipers and caliper bolts on.Took care of the problem.
