![]() Join Date: Sep 2017
Changing rear axle lugs
I have a ZR2 rear axle, and I've started rebuilding it. The lugs on the rear are metric and don't match the ones on the front hubs I got from TCI - 7/16 x 20. After talking to TCI and having the axles out of the tubes for the rebuild anyway, I decided TCI was right and it was going to be easier to replace the rear metric lug bolts with 7/16 x 20. I measured the knurl and got some from Summit that have the measured knurl size of .557".
Now, I need to drill the hubs out, but I talked to an axle shop today and they said the real problem was centering the new hole. I thought I could just use a drill press, and using the right size drill bit, it would follow the original hole and be centered. Am I missing something? Thanks.
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
| Bookmarks |
