Old 06-15-2024, 01:56 AM   #1
skokie
skokie's Avatar
What size is the distributor hold down bolt
Is it distributor hold down bolt 1/2 or 7/16?
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 06-15-2024, 09:43 AM   #2
Dashman
Re: What size is the distributor hold down bolt
It should be 3/8-16 with 9/16 hex head.
Dashman is offline   Reply With Quote
Old 06-15-2024, 09:54 AM   #3
1967GMCC20
1967GMCC20's Avatar
OEM 3/8 but various lengths, depending on distributor, clamp style, and manifold.
Always check that distributor has clearance to oil pump shaft by installing without gasket. Should sit flush on manifold, then, add your distributor gasket.
1967GMCC20 is offline   Reply With Quote
Old 06-15-2024, 11:49 AM   #4
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Mine has a: (GR 5) 9/16” hex flange head bolt. The bolt threads are 3/8-16 x 9/16”, and the head is stamped “E”.
Tony 1971 C10 Custom Deluxe SWB 402/400TH A/C
I developed an assembly information kit for restoring my truck from nuts and bolts. It's written in Assy. order, short & simple, packed with all OEM hardware ID; castings; part ID; 100s of part numbers; wiring simple - Resource, and trivial too.
Much info. applies to all 67-72 GM, A/C vehicles, esp. trucks W/O saying. Full search ability, including to 700+ images of illus., parts, charts, Assy., points of interest, cab, bed, & front clip cart plans- Specials and cores were serviced out and R excluded e.g. front/rear glass, body/paint, engine core, rebuilt hinges, steering box, trans, etc.
The project was in-line with long former professions developing process, policy, specs, demo, written for novices, admin., policy, engineers, development, systems & test - Public & govt 2, gross. Sell soft copy cheaply, PM if interested.
Build thread:https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is online now   Reply With Quote
Old 06-15-2024, 12:00 PM   #5
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
From experience use a factory bolt and clamp as some of the aftrmarket ones are crap and will loosen and let your distributor move around.
1992 K1500 GMC Suburban
" In the end, we only regret the chances we didnt take "
" Time is the only currency we spend without knowing the balance, use it wisely ." ..
Old 06-15-2024, 12:25 PM   #6
1967GMCC20
1967GMCC20's Avatar
Factory clamps are always better.
Old 06-15-2024, 01:50 PM   #7
skokie
skokie's Avatar
Thanks for the info. Going to pick up a set of these when I need to adjust timing etc.
https://www.amazon.com/gp/product/B0...KIKX0DER&psc=1
68 build thread
Old 06-15-2024, 04:13 PM   #8
RustyPile
RustyPile's Avatar
Why go to the internet and wait a week and possibly pay shipping??? O'Reillys, NAPA, CarQuest and most parts suppliers have them on the shelf for immediate purchase...
RustyPile is offline   Reply With Quote
Old 06-15-2024, 04:23 PM   #9
1967GMCC20
1967GMCC20's Avatar
Not to mention every flea market, swap meet.
Old 06-15-2024, 07:15 PM   #10
skokie
skokie's Avatar
Yep. Just threw that out there as what I was looking for.
Thanks!
68 build thread
Old 06-16-2024, 01:28 AM   #11
71CHEVYSHORTBED402
Mine is similar the bottom one, it's ancient and does the trick. If I remember right, it's the only tool I have that remotely works for the lower RH hood hinge bolt with the blower and inner fender mounted.
