Old 06-15-2024, 07:24 PM   #1
skokie
skokie's Avatar
Looking for a borescope
Looking for a borescope and wanted to know what would be a good one that wont break the bank.
Thanks!
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 06-15-2024, 09:25 PM   #2
jerry moss
Born Psycho
jerry moss's Avatar
Smile Re: Looking for a borescope
i bought my dad a Snap On bore scope several years ago and it was not too expensive at the time, i'm sure they have gone up since then, but it has a clear screen and i also bought him the smallest wand so he can look at the inside of a rifle barrel. if i remember correctly it was under $700 with the different size wands. one of my coworkers bought the same one and uses it quite often looking for damage in engine blocks/cylinder heads. it does still pics or video.
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is offline   Reply With Quote
Old 06-15-2024, 10:23 PM   #3
Getter-Done
Getter-Done's Avatar
What about this one?
Link: https://www.vevor.com/pipe-inspectio...p_010690827472
They have more Expensive ones also.
The early bird gets the worm,
84 Chevy K-20
Old 06-16-2024, 12:07 AM   #4
franken
You can go the low buck route and get one that plugs into a phone. I bought one some years ago for less than $20.
franken is online now   Reply With Quote
Old 06-16-2024, 12:39 AM   #5
truckster
truckster's Avatar
I bought this one because it has an articulating camera, so you can look back up at the head and valves:
https://www.amazon.com/gp/aw/d/B0C5D...b_b_asin_title
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 06-16-2024, 02:22 AM   #6
Richard
One was included with the vehicle scanner I purchased some time back. Large size of scanner make use somewhat cumbersome. If I were to buy one would look at many that use my cell as the screen. Really cheap and for as much as I would use it. It would be fine. Amazon, Ebay they are plentiful.
Richard
Old 06-17-2024, 01:47 AM   #7
Killer Bee
Killer Bee's Avatar
really depends on your intended needs and frequency of use
we buy Snap-on scopes at work, one thing I like is the dual camera head
one faces sideways, the other on the end. cheaper than articulating cameras and fits smaller openings
they record and file conveniently for vehicle history records
might be a little excessive for home use but I don't put a lot of stock in cheap electronics
I believe Milwaukee make good sewer cams, they might have a compact automotive application that's reliable
good luck!
Old 06-17-2024, 07:44 AM   #8
I've been using this for many years. Good, economical unit.
https://www.harborfreight.com/digita...era-61839.html
Old 06-17-2024, 11:47 PM   #9
57taskforce
All about them K’s
57taskforce's Avatar
I have a bluetooth unit that is very nice, has a bright LED light on the end of the camera, and is rechargeable. You have to download an app to your phone, but it’s all really easy to set up.
I’m away from home for the week but if I remember I’ll post up the specifics this weekend.
Tyler
57taskforce is offline   Reply With Quote
Old 06-18-2024, 05:52 AM   #10
custom10nut
custom10nut's Avatar
I have a similar one, that I got from Amazon, for around $40.
I Bluetooth it to my iPad so I have a “Big Screen” to look at when I’m using it.
So far it works pretty good.
custom10nut is offline   Reply With Quote
Old 06-18-2024, 04:26 PM   #11
Rust_never_sleeps
Rust_never_sleeps's Avatar
I have this one, it's a few bucks cheaper with the 16' cable, or about $20 more for an articulating end:
https://www.amazon.com/dp/B08QCMT89N
1970 C10 Custom longbed 350/350
Code:
            __
     ______|__]\____
....|___(o)_____(o)_]
Rust_never_sleeps is online now   Reply With Quote
Old 06-19-2024, 04:32 PM   #12
chevmn
Earlier in the year I purchased this
https://www.amazon.com/gp/product/B0...0?ie=UTF8&th=1
It has performed well so far. I know there are better units, but for $50 minus the 25 percent off (I think I paid about $30 at the time), it is tough to beat. And, with amazon, if you do not like it, return it.
chevmn is offline   Reply With Quote
Old 06-25-2024, 12:15 PM   #13
chappys4life
I tried this amazon one twice and it was junk
https://www.amazon.com/dp/B0C4V5LWWL...t_details&th=1
The track that we did circle track at used the milwaukee camera.
chappys4life is offline   Reply With Quote
