Old 01-13-2004, 11:36 AM   #1
hvychvy
Question Power Booster???
I found a power booster at the yard for my girl's 67.It has a new D44 out front with discs.Can I just slap the booster on and run a vacuum line and go?
1969 C10 350,3 speed on floor
1997 Dodge Ram lifted
!967 K10 400,TH350,4" lift,shortbed(girlfriend's truck my envy)
hvychvy is offline   Reply With Quote
Old 01-13-2004, 11:53 AM   #2
69k5
if im understanding this right it has manual brakes then yes bolt the master to the booster, booster to the wall, hook up linkage and vaccumm and go. should probably grab the prop valve while your at it.
69k5
69k5 is offline   Reply With Quote
Old 01-13-2004, 11:59 AM   #3
SWEET7T
Try spinnin 4 rear tars
SWEET7T's Avatar
get the linkage out of the donor vehicle, it is a little bit different length than the manual brake linkage. Other than that, bolt on, plug in and stop easy!
SWEET7T
1970 C10, 2wd, LB, 307/TH350/3.08. PS, PB
SWEET7T is offline   Reply With Quote
