Old 01-13-2004, 11:54 AM   #1
shuttermutt
Don't say "Oops!", Doctor
shuttermutt's Avatar
Drum brake "diving" problem
Hey all! My 68 has drums all the way 'round and the truck has a tendency to "dive" to the passenger side under moderate to heavy braking. Normally, I'd just write it off since nearly every drum brake equipped GM vehicle I've ever driven was the exact same way. However, it seems to be getting a little worse lately. What exactly causes this?
'Mutt
1968 CST LWB: R.I.P.
1967 Chevelle: TPI 454 beast
1967 C10 SWB: Claimed when Bumpster didn't put it on his list
shuttermutt is offline   Reply With Quote
Old 01-13-2004, 11:56 AM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
is your front end components good and not worn ( springs shocks)
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 01-13-2004, 12:00 PM   #3
shuttermutt
Everything appears to be okay. The shocks pass the official "Bounce Test" and the ball joints, tie rods, and so forth are good. No, this definately feels like the passenger front wheel is grabbing hard before the driver's front wheel.
'Mutt
Old 01-13-2004, 12:02 PM   #4
Paul72
Paul72's Avatar
Maybe check the adjustment on the driver's side drum.
'72 Chevy K20 - 383/4sp/205 - SOLD after 41 years in the family
Next project - K/5 Tahoe (71 Blazer on 99 Tahoe chassis) Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=789958
Paul72 is offline   Reply With Quote
Old 01-13-2004, 12:07 PM   #5
CPNE
Resident Curmudgeon
CPNE's Avatar
Usually signifies unequal (higher) pressure to side it pulls toward.
Had 68 burb with EXACT same problem. Replace your wheel cylinders (most likely culprit). While yo have it torn down you might as well replace hoses, shoes, and toss in a Maxi-pack. This will solve your problem.
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 01-13-2004, 12:14 PM   #6
shuttermutt
I figured it was an adjustment and/or worn brake part issue. What's a Maxi-pack? I'm pretty sure my truck's a male.
'Mutt
Old 01-13-2004, 12:15 PM   #7
Paul72
Paul72's Avatar
LOL
Old 01-13-2004, 12:21 PM   #8
CPNE
Resident Curmudgeon
CPNE's Avatar
Sorry, that's what the local NAPA calls a kit containing all new springs and retainers for your brake shoes. Sorry, they don't make the style with "wings".
Old 01-13-2004, 12:34 PM   #9
shuttermutt
Ah... groovy!
'Mutt
Old 01-13-2004, 02:12 PM   #10
gr8scott51
gr8scott51's Avatar
Look for leaks
If your wheel cylinder is dripping brake fluid on your shoes, they will grab. I know.
Silence is golden, duct tape is silver. - Scott
gr8scott51 is offline   Reply With Quote
Old 01-13-2004, 03:09 PM   #11
67Fleetsidedream
Wiseass secured himself a BAN
67Fleetsidedream's Avatar
I would bleed the brakes and see if that fixes it. You may have air in the lines. If that doesn't fix it then you will need to replace the brake cylinders on the side that it is not grabbing on.
67Fleetsidedream is offline   Reply With Quote
Old 01-13-2004, 03:48 PM   #12
Rooster's 67
Rooster's 67's Avatar
just convert it over to disk and be done with it.
The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself?
Rooster's 67 is offline   Reply With Quote
Old 01-13-2004, 04:14 PM   #13
shuttermutt
Easier said than done, my friend. When it's not 10 below zero, I'm not in the middle of a 1,700 mile move, and I have a garage again, then I'll consider the disc brake conversion.
'Mutt
Old 01-13-2004, 10:10 PM   #14
86SILVERADO
86SILVERADO's Avatar
Mutt,
I hear ya Bro. course it's only in the single digits here. Hope you are headded south!
86 Silverado C10 back to 305 power!
67 C30 Dually Dump, with 350 transplant, Rockhauler
05 Duramax 3500
"If at first you don't succeed, try a bigger hammer"
Member of the 1-Ton club!
86SILVERADO is offline   Reply With Quote
Old 01-13-2004, 10:28 PM   #15
68 Suburban
68 Suburban's Avatar
Could be a sign of a week front passenger spring. After 35 years of the engine torquing to that side, it tends to weeken the spring. I bet if you look at a lot of these old trucks, they sit and inch or two lower on the front passenger side.
68 Suburban is offline   Reply With Quote
Old 01-13-2004, 10:45 PM   #16
shuttermutt
Well, no. I'm going a little South, but much more West. From Northern Maine to Minnesota. Woo-hoo!
'Mutt
Old 01-13-2004, 10:54 PM   #17
Rooster's 67
i hear ya shuttermutt bout the whole fun situation ya got goin on.
look for grease or brake fluid on the shoes, and possibility of a colapsed hose on the front left is possible too. restricting the fluid flow to the left cylinder.hardware on the brakes can affect it too, so can adjustment.
dont totaly overlook the rears, a pull to one side can be caused by a rear on one side having an issue, but yours sounds like it is in the front.
Old 01-14-2004, 12:14 AM   #18
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
The first thingi would doo is djust the brake adjuster, and if it does not turn freely, remove the drum and clean up the adjuster and put some antiseize compound on the threads.
Being that it is getting worse, that tells me that his drivers side shoes are not adjusting much, if any, and the wear is making them more and more out.
Try that while keeping an eye open for fluids coming out teh bottom of the drum, and also for crushed brake lines.
Old 01-14-2004, 12:34 AM   #19
68CST327
I have the same brake diving problem too. I checked underneath the truck the other day and I'm leaking fluid all over the inside of the right rear tire, so I'm thinking it's probably the wheel cylinder that needs replacement. Also interesting that a problem in the rear can cause the brake drag in the front, but I think that's probably what the problem is on my truck. Thanks to everyone in this thread for the new info.
68CST327 is offline   Reply With Quote
Old 01-14-2004, 12:54 AM   #20
Blue Beard
Blue Beard's Avatar
I have the same problem, but haven't found any leaks. New springs, hard brake pedal.........
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 01-14-2004, 01:02 AM   #21
Longhorn Man
Can you explain that? I see no way this can physicly happen...nor have I ever seen it on any old stuff, nor new vehicles.
Old 01-14-2004, 01:36 AM   #22
68CST327
I dunno, I read it somewhere in this thread.
Old 01-14-2004, 08:10 AM   #23
Longhorn Man
OK, I think you misread what was actually ment.
If your left rear brake is dragging, it will pull the truck to the left, much like if it was a front brake. This can actually be misleading when trying to troubleshoot it on a test drive.
Old 01-14-2004, 01:01 PM   #24
68CST327
Yeah, I pretty much got that idea when I read it the first time, but somewhere along the line when I typed my response back out, I got things mixed up.
Forgive me, too many long days at work + not enough sleep at night =
I should have typed: "Also interesting that a problem with the brakes in the rear can cause what seems like brake drag in the front."
Old 01-14-2004, 05:31 PM   #25
Jace's68
Jace's68's Avatar
Things to check.
1. Make sure both font brakes are adjusted the same.
2. Check for wheel cylinder leaks.
3. Could also be caused by a bad rubber brake hose. If one side is getting more fluid pressure, it will cause it to pull like you described.
4. One other thing is to make sure that the shoes are installed correctly. The short shoe goes in the front, and the long shoe in the rear. I have seen lots of people get this wrong.
I had the same problem with the 68 I just bought. When I inspected my brakes everything needed to be replaced. After replacing both front hoses, one wheel cylinder and installing a new set of shoes the problem is gone. I hope this helps.
Jace's68 is offline   Reply With Quote
