06-20-2024, 10:46 AM | #1 |
JB TankWeld technique
Hi,
I have a leak in my 20 year old steel blazer tank, its located behind the strap, about 3 inches up from the bottom (its on the side of the tank). It is a 1/16" round hole. I don't detect any other weak spots. I'm going to attempt the JB TankWeld product. I'm contemplating tightening a small screw into the hole, tightening it down through the JB stuff before it cures and pressing JB over and around the screw head, or skipping the screw and just using JB. Obviously this low in the tank, the patch will have gas sitting against it at all times. Has anyone attempted this technique? Ryan |
06-20-2024, 11:49 AM | #2 |
Re: JB TankWeld technique
I would pull it out and have it cleaned and a soldered patch put on from a radiator shop
06-20-2024, 12:21 PM | #3 |
If this is a '69-'72 Blazer, the new tanks with correct filler neck are just over $200.
1970 K/5 Blazer CST 4WD, Medium Bronze, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion.. 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... 2017 Sierra 1500 SLT 4WD, Black, 45k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 62k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
06-20-2024, 01:03 PM | #4 |
I have used JB Weld for tanks before it works well. The big key is to be sure the arear is clean of "everything". Sand it to help the JB bite in tight and use thinner to clean away any conminates from the area. I use regular JB at my shop to fix all kinds of stuff for customers. If done right it works great.
Harley 1969 Chevy C-10 Long Bed, 350cid, 700R4 |
06-20-2024, 04:23 PM | #5 |
JB Weld is good stuff but....a patch is still a patch.
06-20-2024, 05:03 PM | #6 |
My plan is to give JB a try, if it fails at least I tried. This is a Blazer tank mounted under the bed of a 67 stepside, and has a custom fill tube that I would prefer not to have to recreate on a new tank, so my plan is to first try the patch, if that fails remove the tank and inspect it to determine Plan B.
Thoughts on using a screw vs just JB Weld? |
06-20-2024, 06:29 PM | #7 |
This may sound silly but couldn’t you fill it with water then weld it
06-21-2024, 09:58 AM | #8 |
Very true but like me not all of us can buy everything new.
06-21-2024, 12:04 PM | #9 |
The screw idea sounds good to me. If the screw stops the leak long enough the JBW will set up dry.
George |
06-22-2024, 08:43 AM | #10 |
I used some kind of fuel tank epoxy stuff (might have been jb weld) on a tank a couple of years ago. Put it on while the leak as actively dripping. I sanded the spot and stuck it on. It worked great. About a year later another leak developed in another spot and I patched it the same way. Then I bought a new tank.
Summary: you don't need the screw. The stuff works great. But, start saving for a new tank. I highly doubt that is the only weak spot. |
06-22-2024, 01:43 PM | #11 | |
I would use the screw and JB weld. Then put Seal-All over the Jb-Weld. Seal all last a long time. Link: https://www.amazon.com/Seal-All-3801.../dp/B008VK0JS4
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
06-22-2024, 04:05 PM | #12 |
All about them K’s
I’ve used JB a couple times on an old S-10 blazer gas tank. It was the clay type stuff they make specifically for gas tanks and it works really well even when it’s dripping fuel from the hole.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
08-29-2024, 07:27 PM | #13 |
Update - I did try JB Weld and so far its working. I put a screw into the hole and buried that in the JB Weld TankWeld product. I let it cure for a week and put half a tank of gas in, so far no leaks.
If that ever changes and it leaks I'll post a revision. |
08-29-2024, 11:04 PM | #14 |
Maybe skip the JB Weld, put a rubber gasket on the screw and you now have a drain plug
