Old 06-21-2024, 10:02 AM   #1
Loose Screw
Loose Screw's Avatar
what lugs do I hook up a remote starter up to?
On the solenoid there are (3) lugs. I know for sure which one is V+.
And then there's the "R" and "S" lug.
I got a push button remote starter with Black and Red jumpers, which wire goes where?
Thanks guys!
Loose Screw is offline   Reply With Quote
Old 06-21-2024, 10:26 AM   #2
Wrenchbender Ret
Re: what lugs do I hook up a remote starter up to?
One wire goes to the S term & the other to the hot term. V+ ?
George
Wrenchbender Ret is offline   Reply With Quote
Old 06-21-2024, 10:27 AM   #3
LNP
To the "S" "S" is for the activation of the starter. "R" is for older models to supply power to the ignition coil while cranking.
Harley
1969 Chevy C-10 Long Bed, 350cid, 700R4
LNP is offline   Reply With Quote
Old 06-21-2024, 10:29 AM   #4
kwmech
Easier to utilize a remote when you rewire with a ford solenoid to help eliminate the heat soak issue------ if present
Old 06-21-2024, 11:35 AM   #5
Loose Screw
So, Black Remote Starter Jumper Wire To "S" Solenoid Lug
And, Red Remote Starter Jumper Wire To "V+" Solenoid Lug
Right?
Old 06-21-2024, 11:59 AM   #6
Wrenchbender Ret
Right?
I'm not sure what V+ is but a good term that is hot all the time like the pos. bat cable. It really doesn't matter which jumper wire goes to each one.
George
Old 06-21-2024, 12:05 PM   #7
RustyPile
RustyPile's Avatar
Right?
A remote starter switch is a simple momentary single pole, single throw switch.. There is no need to observe polarity on the wires.. One lead (either one) connects to the "S" terminal (the one closest to the engine block) and the other lead connects to the positive post of the battery, or the top post on the starter solenoid which is the other end of the positive battery cable..
RustyPile is online now   Reply With Quote
Old 06-21-2024, 12:10 PM   #8
LNP
Right?
No. One wire to the "S" terminal and other to the battery Positive terminal (V+)
Harley
Old 06-21-2024, 08:27 PM   #9
Steeveedee
Who Changed This?
Steeveedee's Avatar
Depending on how long the wires are, I'd hook the cable clamps to the starter's "S" terminal and the battery positive post. Reason being that it's possible for those clamps to turn while you're working, and ending up with constant cranking when they short together, and you might not want that. Easier to pop the clamp off the battery, up where you are punching the button.
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 06-22-2024, 08:53 AM   #10
Loose Screw
Yeah Hey Thanks Everybody! I did hook up the remote starter button to the positive terminal on the battery and the "S" terminal on the starter motor's solenoid.
No go, I got some electrical problems somewhere along the line.
My arms are sore from hassling with starters yesterday and my ears are sore from listening to my ole lady complaining about her losing her garage spot for her Honda....
I'll start back on this once I recover...
Old 06-22-2024, 09:26 AM   #11
yuccales
yuccales's Avatar
Ask her if her Honda can do "truck stuff". Hope you get the wiring figured out.
yuccales is offline   Reply With Quote
Old 06-22-2024, 01:28 PM   #12
Getter-Done
Getter-Done's Avatar
Hope you get it going.
You need a dose of Selective hearing
I have to use that often with my Better Half.
The early bird gets the worm,
84 Chevy K-20
Old 06-22-2024, 01:29 PM   #13
Getter-Done
84 Chevy K-20
Old 06-22-2024, 04:15 PM   #14
RustyPile
RustyPile's Avatar
I'll not hesitate to offer advice on finding that electrical problem, but I draw the line at offering marital harmony advice.. I've been married to the same woman for only 58 years so I don't have a lot of experience in that department...
Old 06-22-2024, 04:48 PM   #15
Loose Screw
***I admire you both!***
Me and my Wife have 40.
Ha! and I just got finished scrolling over X (twitter) and there was a question, "What Would You Do If You Could Time Travel to 1986?",
I'd go back and tell my Wife "Thank You".....
Old 06-22-2024, 09:24 PM   #16
yuccales
yuccales's Avatar
That is very nice.
Old 06-24-2024, 11:13 AM   #17
LNP
If you are jumping the starter direct which the way you explained it you are. And the starter did not turn over then you have either a bad positive wire connection from the battery to the starter or a bad starter.
Harley
Old 06-24-2024, 03:40 PM   #18
Loose Screw
Thanks Amigo!
Oh Yeah, we're going to get into this, *maybe* in a day or two I'll start asking a bunch of confusing questions. I have other life things pushing on me right now. Aaand the triple digit weather ain't helplng............
Safety First/Safety Always...And Drink Lots Of Water!
Old 06-24-2024, 04:29 PM   #19
Wrenchbender Ret
Make sure your remote switch is good. I've seen them burned out by a guy hooking it across the main terms. on a Ford solenoid.
George
Old 06-24-2024, 10:02 PM   #20
Loose Screw
Ok, I'm going to start a New Thread on the Hunt for a new Starter and it might get into lockout switches, messed up wires and voltage regulators...one thing at a time , Starters...See You There............
