Old 06-21-2024, 02:52 PM   #1
supertrooper
1967 GMC 930 Manual Trans Fluid?
The manual calls for “straight mineral oil gear lubricant”. I am not finding any locally. Does anyone know if there is a modern replacement for this?
supertrooper is offline   Reply With Quote
Old 06-21-2024, 05:02 PM   #2
RustyPile
RustyPile's Avatar
Re: 1967 GMC 930 Manual Trans Fluid?
My Chevrolet Manual says SAE 80 or SAE 90 GR5.... Same for all manual transmissions.
RustyPile is offline   Reply With Quote
Old 06-21-2024, 05:20 PM   #3
'68OrangeSunshine
'68OrangeSunshine's Avatar
Any non-synthetic gear oil will work. For your latitude, a viscosity of SAE 75 to 95 will work. By ''Straight'' they seem to want a single viscosity, not a multi grade. SAE 90 might work. 80W - 140 would be good for the Desert Southwest.
Also if you have an SM 420 transmission, with brass synchros, you want service GL-4. GL-5 has additives for limited slip [Positraction] but these additives attack brass synchros.
''Mineral Oil'' refers to natural petroleum oil, not Synthetic. In 1967 synthetic lubricants were rare. Much has progressed in this field since then, but if you want to go by the book, avoid them.
Old 06-21-2024, 05:33 PM   #4
supertrooper
My dad was doing some reading and came across something that said to make sure there is no sulfer in it…?
Old 06-21-2024, 05:51 PM   #5
1970cstblazer
1970cstblazer's Avatar
Lightbulb Re: 1967 GMC 930 Manual Trans Fluid?
GL-4 80w90
1970 K/5 Blazer CST 4WD, TOTM winner December 2024! Medium Bronze poly, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD Kelsey Hayes wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion..
2017 Sierra 1500 SLT 4WD, Black, 46k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 67k miles, 3.6, 8L45, 3.23 LS, 18" wheels
Old 06-21-2024, 06:36 PM   #6
supertrooper
Looks like this is what I am looking for. My dad did some more checking found someone that also recommends the GL-4. Most is GL-5 and not what the transmission wants.
Here is a quote from Penngrade oil.."PENNGRADE 1® CLASSIC GL-4 GEAR OIL SAE 80W-90
PennGrade 1® Multi-Purpose ‘Classic’ Gear Oil GL-4 SAE 80W-90 is a specially blended using high quality premium mineral base stocks and select additive technologies. It is designed to be used with “yellow” metallurgy (brass, bronze, copper) and other ‘soft’ metals used in synchronizers, bushings, thrust washers and other components typically found in classic manual transmissions and transaxles. In applications specifying API GL-4 quality lubricants, use of API GL-5 lubricants with higher extreme pressure additive activity/concentration can damage these ‘soft’ metal components."
This makes perfect sense and I am confident now to replace the fluid with a GL-4.
Thanks!
Old 06-21-2024, 06:36 PM   #7
'68OrangeSunshine
GL-4 80w90
Sounds good. Why was GM leery of multi viscosity 57 years ago?
They call for ''Straight'' oil.
Old 06-21-2024, 06:48 PM   #8
kwmech
GL-4 80w90
Right there. Have found out a couple of times when a customer has had their vehicle serviced elsewhere and then starts experiencing shifting issues. Drain and fill with GL-4. The GL-5 is too slippery for the brass rings to grab the gear and slow it down
Old 06-22-2024, 05:27 PM   #9
jumpsoffrock
Where do you pick up your GL-4, mech?
jumpsoffrock is offline   Reply With Quote
Old 06-22-2024, 06:21 PM   #10
'68OrangeSunshine
Supertrooper: What transmision do you have?
Old 06-23-2024, 07:35 AM   #11
1970cstblazer
I just picked up a bottle of Valvoline GL-4 at my local Carquest. It was $13.
