Old 06-21-2024, 08:20 PM   #1
D-n-Tyke
To Cut the Springs or Not to cut the springs, that is the questions
So when we built this truck I bought modular drop spindles and then 1" drop springs for the front and 4" drop springs and a 1" block for the rear to get me a 3/5 static drop. Now after driving it for a year and everything settling in I feel that the front end is still to high. I wanted a slight rake to the stance and feel I have a level stance with to much open wheel well in the front. So I think I want to drop the front another inch.
So my question is, do I spend the money and buy new 2" drop springs (really don't want to spend the money). Or do I just cut the 1" drop springs I have. And if I were to cut them would I just cut half a coil to get the 1" drop?
Help me out guys. What is your guys' experience and advice?
69 C20 for reference. All suspension pieces are from CPP if that matters.
D-n-Tyke is offline   Reply With Quote
Old 06-22-2024, 04:16 AM   #2
jjzepplin
jjzepplin's Avatar
Re: To Cut the Springs or Not to cut the springs, that is the questions
I cut my springs to see how low I want the truck to be. I don't think I am going to drive it with them though. I am going to put the right stuff under there. Do you have another set that you could toy with? You could sell these the way they are but once you cut them...
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 06-22-2024, 05:35 AM   #3
rob32472
If you are on a budget and want to see what it's like cut away. I am sure some may disagree but I think everyone who is into hot rodding has done it. Road kill garage does it all the time. You probably will find in the end you will want to put the right stuff under it though. Either way you will probably throw away the springs so no harm really. Have fun and enjoy.... BTW cut half a coil at a time and set back on the ground until you are happy with the stance.
rob32472 is offline   Reply With Quote
Old 06-22-2024, 09:48 AM   #4
KQQL IT
At the body shop.
KQQL IT's Avatar
My 73 has been on cut coils since 2005 hasn't changed height yet
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is offline   Reply With Quote
Old 06-22-2024, 10:33 AM   #5
bowtie72
bowtie72's Avatar
I have been running cut coils. There is nothing wrong with it. If you only cut half a coil it wont set in the lower control arm correctly. Which could cause other issues. I old suggest cutting a full coil.
1968 SWB "Little White Truck"
1972 LWB LS 4l80 "Plain Jane!!"
bowtie72 is offline   Reply With Quote
Old 06-22-2024, 11:11 AM   #6
dagnabbitt
dagnabbitt's Avatar
You mention that it is a C20: are you using C10 drop springs, or are these the drop springs for a 3/4 ton?
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 06-22-2024, 01:03 PM   #7
CAMAROBOY68SS
CAMAROBOY68SS's Avatar
Ive been running coils with half a coil cut for a couple years now with no issues up front. Have cut coils of loads of other cars with no problem when you stick to trimming a single coil maybe 2 at the most. There is a limit of how far you can go.
The Twins:
1968 C10 SWB - Blue 327/5 Speed
1968 Camaro SS/RS - Blue 327/4speed
C10 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=833278
The "Others"
1933 Ford Pickup (Camaro in disguise)
2017 Camaro SS
Life long Chevy guy
CAMAROBOY68SS is offline   Reply With Quote
Old 06-22-2024, 01:42 PM   #8
Wikid61
Wikid61's Avatar
If ya need to really cut only a half 1/2 coil, you may drill & put a grade 8 nut & bolt to keep it still.
Wikid61 is offline   Reply With Quote
Old 06-22-2024, 02:22 PM   #9
D-n-Tyke
I believe they are C10 drop springs (CPP PN: FCS6102-1). They were part of the complete kit(6572LHP-K) I bought from CPP.
Old 06-22-2024, 02:29 PM   #10
D-n-Tyke
So now I am little torn. I like the idea or whittling down and adjusting the height buy cutting the springs. But then again I like the idea of buying the correct sized spring and then putting this set up for sale and recouping some of my money back. Decisions...decisions...decisions.
Appreciate all your guys' input.
Old 06-22-2024, 06:49 PM   #11
CC69Rat
CC69Rat's Avatar
Just my .02
A coil spring is nothing more than a straight piece of steel rod that's coiled up to produce torsional rigidity. The length of the coil matters, absolutely but also the spring rate makes a difference in the overall height / net drop.
Diving boards also use torsional rigidity. Think of a 12ft diving board. 250lb man. Bounces on the end,.. and into the water. How much did the board flex?
Now cut two foot off the board. Does the board flex the same? Or is it stiffer?
I have cut spring before.. not saying don't cut them. I'm just saying spring rate matters.. so if you cut the 1/2 coil it may not net the drop you're looking for... it may net more. It really depends on the spring rate combined with how much you cut off. One full coil will be at least 2" in my opinion but it will give you a harsh ride and need an alignment.
I'd just replace the springs and sell the ones you have now. Hope this helps.
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
