Old 06-23-2024, 12:38 AM   #1
howzzzit
howzzzit's Avatar
Beauty rings and valve stem length
I'll be installing tires on new rally wheels and using the deep 3 inch beauty ring. Do I need a longer than normal valve stem or just use short extenders if necessary? What have you run into?
howzzzit is offline   Reply With Quote
Old 06-23-2024, 01:13 PM   #2
Jeff M.
Jeff M.'s Avatar
Re: Beauty rings and valve stem length
I just used the short extenders on the wheels that had the short valve stem.
69 C-10 CST Short Fleet, Factory Air, BB427-400 Auto-2400 stall-tilt-cruise-Tach & Vac Gagues, 4/6 drop, power one piece side windows, Eaton posi.
Jeff M. is offline   Reply With Quote
Old 06-23-2024, 04:21 PM   #3
LS short box
Since you going to have the tires off just install the rings on the wheel with the tire off and get the correct length valve stem from the tire shop.
LS short box is offline   Reply With Quote
Old 06-23-2024, 05:38 PM   #4
Sheepdip
Sheepdip's Avatar
I might suggest also not just the correct length but in stainless steel.
https://www.amazon.com/CK-Auto-Piece...43zLJf27qXwtWw
Sheepdip is offline   Reply With Quote
Old 06-23-2024, 07:34 PM   #5
howzzzit
howzzzit's Avatar
Extenders it will be if necessary. I wouldn't put the beauty rings on first. Tire people would probably ruin them. Thanks for the replies.
Old 06-24-2024, 07:18 PM   #6
purple gas
If you take the rim and the ring to the shop they will be able to determine the length of stem.
Unless they're 100% incompetent ( not impossible, I used to work in the tire shop supply & equipment business) there should be no way they can ruin your rings.
Anytime I've replaced tires I get new stems, stems can fail, especially if they're old.
If you get the proper length stems you don't need extensions, they can also fai, leak, or fall right off.
It'll cost a few extra bucks to do it right, but a flat or leaky tire can ruin your day,
I got a bench seat baby, you don't have to sit over there.
purple gas is offline   Reply With Quote
