Old 06-24-2024, 10:10 PM   #1
K10-Kansas
K10-Kansas's Avatar
Bouncy
It's not normal to have a bouncing speedometer needle right? I'm just guessing this is because my mechanical speedometer cable is maybe a little too bent between the speedometer and the transmission?
https://youtu.be/cgQgB1cqlBY?si=j2SYxqHGtptG1apH
1971 C10 manual cab. 76 4x4 chassis. Cut short frame. Carbureted Blueprint 350, automatic 700r4. ~ James
K10-Kansas is offline   Reply With Quote
Old 06-24-2024, 10:32 PM   #2
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Bouncy
Yep, not normal. Tight bend(s) in cable might be the culprit. Also, any chance the cable is not well-lubed inside its housing?
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 06-24-2024, 10:39 PM   #3
K10-Kansas
K10-Kansas's Avatar
Re: Bouncy
I bet it's not lubed at all I'll lube it tomorrow. Thanks. I didn't even think of that.
Old 06-25-2024, 12:13 AM   #4
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: Bouncy
Mine used to do that. For reasons I'll never know, the cable was not properly attached to the speedo. Got it hooked p, it's working fine.
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
