Old 06-28-2024, 12:16 PM   #1
aglinks
LS Engine Mounts in 1966 K10
Does anyone know which mounts to use for a 5.3L LS in a 1966 GMC K10 chassis?
The more dig, I think my truck is a GMC chassis because it has the 305 V6 with factory riveted engine mounts towards the front of the block.
aglinks is offline   Reply With Quote
Old 06-28-2024, 11:13 PM   #2
cwcarpenter98
cwcarpenter98's Avatar
Re: LS Engine Mounts in 1966 K10
The frame rails are going to be the same, you just need to get the typical mounts for fitting an LS to the chassis. You will need to remove the GMC V6 frame stands and replace them with whatever the LS needs
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 350, Saginaw 4 speed
Old 06-28-2024, 11:18 PM   #3
aglinks
My truck does not appear to have the same crossmember that the 2WD trucks have. That crossmember looks to be where the pedestals land…
Old 06-28-2024, 11:33 PM   #4
cwcarpenter98
Oh right, my bad! I completely forgot that the 4wd trucks have different crossmembers. Hopefully someone who has already done an LS swap on a 4wd will chime in
Christian Carpenter
